Introduction: Create Mesmerizing Drawings on a Stand Mixer!
When I came across the Cooking Contraptions Contest I immediately got excited and wanted to make something fun out of a "boring" everyday item. I was asking myself: which kitchen appliance can I use in a safe, fun way? I didn't want to mess with AC power, heat elements or sharp objects.
The stand mixer was the perfect choice! It has a front (and sometimes top) hub designed for modularity and add-ons. I decided I want to attach something to the stand mixer's front hub and use its easy mounting and variable speed, and after many ideas and experiments I made a gadget for drawing on paper coasters.
My gadget is inspired by Barton Dring's Polar Coaster and I highly recommend his blog full of cool machines and great explanations.
Tools:
- 3D printer and some filament - I used standard PLA filament
- Soldering iron -
- Metric Allen wrenches
- Metric Combination Wrenches
- Hacksaw or any other tool to cut the brass standoff
OTS (off-the-shelf) Parts:
- (1) 688zz Bearing (8mmID 16mmOD 5mmL)
- (1) 15mm F-F M6 Hex Standoff - I bought an 80mm standoff and cut it to length
- (1) DIN 7991 M6x40 (Hexagon socket countersunk head screw)
- (2) DIN 7991 M3x10 (Hexagon socket countersunk head screw)
- (2) M3 Heat set thread insert
- 3.5" Paper Coasters
Optional:
- Soldering iron tips for heat set inserts - I don't have these, so I just use a standard conical tip
Step 1: Design
I designed the T-Vault using Fusion 360 - Why?
- Free for hobbyists
- Easy to use without extensive CAD experience
- There's a built-in McMaster-Carr interface which makes working with COTS hardware so simple
- There are tons of plugins and add-ons available
- Creating illustrations and animations (like the ones in this Instructable) is very simple
The 1st task was to take measurements from the hub itself and create a 3D model. For my purpose I only needed the inside part of the hub, so I created 1 component for the drive socket and another component for the plastic housing, the screws were added mainly for aesthetics.
Next, I needed to design the part that will lock into place inside of the hub. This stand mixer (made by Kenwood) utilizes a quarter-turn bayonet, so I designed a part that can be inserted into the hub and then rotated to lock. It took some trial and error but after a couple of tests my bayonet was done.
After I had the hub itself and the bayonet mechanism, I could basically attach anything I wanted to the stand mixer, in the attached section you can see how the parts are stacked to allow for rotation without axial movement.
For the coaster Holder itself I have remixed Barton Dring's design.
Step 2: Print the Parts
I printed all parts using my default setting:
- 3 walls/perimeters
- 20% infill
- Brim
- No supports
- You can see the suggested print orientation in the attached image
There are 5 files, print 1 of each:
Step 3: Install Heat Set Threaded Inserts
Using a soldering iron, install (2) M3 heat set threaded inserts into the bayonet.
- Place the insert above the holes and gently press them in until the smooth part enters the hole
- Make sure the insert is perpendicular to the surface, otherwise it will be difficult to fix it later on
- Let the soldering iron heat up, if you have an adjustable temperature soldering iron, I suggest ~230deg c.
- Hold the soldering iron above the insert, try to align the tip with the internal thread
- Slowly press the insert using the soldering iron until it is flush with the printed part's surface
- Inspect the insert and make sure there is no molten plastic inside the thread
- Repeat 4 times
When installing the inserts, try to be as perpendicular as possible
If you have designated tips for threaded inserts - use them! Otherwise, use a standard conical tip and make sure you clean it from any plastic residue after you are done.
Step 4: Assemble!
Take a look at the exploded view above and assemble (it is pretty striaght-forward and there's not a lot of room for error). The only tools you'll need are 1.5mm & 4mm Allen wrenches and a 10mm Combination Wrench to tighten the screws.
Step 5: Start Drawing!
Important! Only attach or detach while the stand mixer is turned off!
- Take the assembled rotary gadget and gently insert it to the stand mixer's hub
- Rotate to lock
- Place a paper coaster, make sure the external teeth are holding it in place
- Turn on the stand mixer, start with low speed and carefully adjust it
- Use pens or markers to draw and make sure you don't apply too much pressure on the coaster holder
