Introduction: Create Your Custom LED Logo With WS2812B and WLED
About: I create projects for my videos that I publish on my YouTube channel
In this project, I’ll show you how I created my illuminated logo using WS2812B LEDs controlled via WLED and a D1 Mini, all enclosed in a 3D-printed frame. I decided to share it because I hope it can inspire you and give you the right tips to create your own custom logo original, bright, and truly unique! Let your creativity shine!
️ MATERIALS LIST:
➡️ Amazon Links
WS2812B Neopixel LED: https://amzn.to/3XRSiMd
1000uf 35V Electrolytic Capacitor: https://amzn.to/3yeZoRd
Screw Connectors: https://amzn.to/46mLQQe
Breadboard: https://amzn.to/4cVSorr
5V Power Supply: https://amzn.to/46oBOOB
Female Jack 5.5x21 Socket: https://amzn.to/3SokwLM
Female Pin Strip + 90° Pin Strip for PCB: https://amzn.to/3yiKCsL
➡️ Aliexpress Links
WS2812B Neopixel LED: https://s.click.aliexpress.com/e/_DBCWGlx
Electrolytic Capacitor: https://s.click.aliexpress.com/e/_DdZM7dp
Screw Connectors: https://s.click.aliexpress.com/e/_DlX7Ruz
Breadboard: https://s.click.aliexpress.com/e/_Dk1xwd7
5V Power Supply: https://s.click.aliexpress.com/e/_DDVvGjR
Female Jack 5.5x21 Socket: https://s.click.aliexpress.com/e/_DC8mDtz
Female Pin Strip for PCB: https://s.click.aliexpress.com/e/_DExmeX5
90° Pin Strip: https://s.click.aliexpress.com/e/_DEwW54b
➡️Download File 3D:Makerworld
Step 1: 📐3D Design & Printing
The logo was designed in 3D and printed in PLA. The main parts are 3 mm thick (15% infill), and the light diffusers are 1.5 mm thick with 100% infill to ensure proper light diffusion.
Step 2: 🔩Frame Assembly
We use two-part epoxy for the main frame and cyanoacrylate glue for the rear spacer. This spacer hides the electronics behind the lightning bolt section of the logo.
Step 3: 🌈Installing the LED Strip
Measure and cut the LED strip as needed. Solder the wires at both ends before attaching it inside the lightning bolt. Ensure the signal flow follows the correct direction.
Step 4: 🔌Mounting the Electronic Components
Solder a connector for the LED strip to the D1 Mini, create a connector using the perfboard, screw terminals, and pin headers, and fix both components in place with hot glue in the logo area. Also solder the capacitor and place it in its slot, connect the LED strip, and finally secure the power cables as well. Follow the included wiring diagram.
Step 5: 💾Installing WLED
Connect the D1 to your PC and go to install.wled.me. Install the latest stable version (check the link for the full tutorial), configure Wi-Fi, device name, max current, GPIO pin (2), and number of LEDs (e.g., 141).
👉 WLED Tutorial on ESP32: Installation and Configuration for LED Strips
Step 6: 🔧Segment Setup & Presets
To control each part of your logo separately, create segments in WLED (e.g., lightning, right side, left side, outer ring). Assign different colors/effects to each. Save your combinations as presets, then create a playlist to rotate them automatically.
Step 7: 🧷Wall Mounting
Create a stencil using a white sheet to mark the wall holes. Mount the sign and attach the hooks.
Step 8: 🌟 Final Result & Control
Connect the power supply, and start playing with colors, effects, segments, and presets. The result is stunning and infinitely customizable!
Step 9: 🎉Final Thoughts
And there you have it — your custom glowing logo is ready to shine! 🎉
I hope this project inspired you to dive into the world of LEDs, 3D printing, and DIY electronics. Not only is it a stunning piece of decor, but it’s also a fun way to get hands-on experience with WLED, soldering, and thoughtful design.
The best part? Every logo is one of a kind, and you can easily switch up the colors, effects, and animations anytime — all from your phone.
