Introduction: Create a Budget DIY Intruder Alarm With an ATTINY 85
The idea is to take an old speaker and generate an intruder alarm from an ATTINY85 when a signal is detected.
A button is used to simulate sensor triggers but PIRs etc can be used instead.
ATTINY85
Old speaker
Breadboard
9 volt battery
LM7805 - 9volt to 5 volt convertor
Dupont cables
Button
Step 1: Programming the ATTINY85
To program the ATTINY85, follow the instructions on https://www.instructables.com/15-Dollar-Attiny85-...
and use this code in the Arduino IDE
/* TinyTone for ATtiny85 */
//clock 1mhz internal
//usbasp programmer
// Notes
const int Note_C = 239;
const int Note_CS = 225;
const int Note_D = 213;
const int Note_DS = 201;
const int Note_E = 190;
const int Note_F = 179;
const int Note_FS = 169;
const int Note_G = 159;
const int Note_GS = 150;
const int Note_A = 142;
const int Note_AS = 134;
const int Note_B = 127;
int Speaker = 1;
void setup()
pinMode(Speaker, OUTPUT);
void loop()
playTune();
delay(10);
void TinyTone(unsigned char divisor, unsigned char octave, unsigned long duration)
TCCR1 = 0x90 | (8-octave); // for 1MHz clock
// TCCR1 = 0x90 | (11-octave); // for 8MHz clock
OCR1C = divisor-1; // set the OCR
delay(duration);
TCCR1 = 0x90; // stop the counter
// Play a scale
void playTune(void)
TinyTone(Note_C, 4, 50);
//TinyTone(Note_D, 4, 500);
//TinyTone(Note_E, 4, 500);
//TinyTone(Note_F, 4, 500);
TinyTone(Note_G, 4, 50);
//TinyTone(Note_A, 4, 500);
//TinyTone(Note_B, 4, 500);
//TinyTone(Note_C, 5, 500);
Step 2: Instructions
After programming the ATTINY85, the steps are as follows:
1. Connect Pin 3 LM7805 to VCC Attiny85 and Pin 2 to Gnd Attiny85
2. Connect Pin 1 LM7805 to +ve 9V battery and Pin 2 LM7805 to -ve 9V battery
3. Add +ve terminal speaker to pin 1 Attiny85 and -ve terminal speaker to Gnd Attiny85 (via Dupont cable)
You can also add a button by changing step 3 to
3. Add +ve terminal speaker to pin 1 Attiny85 and -ve terminal speaker to button pin, then connect diagonally opposite button pin to Gnd Attiny85 (via Dupont cable)
Step 3: Next Steps
A variety of different sensors may be used to trigger the circuit , including PIR , Ultrasonic and manual switches. The output from the speaker may be amplified using an LM386 module widely available on E-bay.
Please ensure that you adhere to strict electrical safety guidelines, i.e.
1. Seek guidance from a person competent in electrical safety such as a qualified electrician.
2. Use low voltage.
3. Ensure that all connections are secure, cables are intact and do not lead to electrical shorts.
4. Etc
