Adjustable Arm Tablet Stand
Intro: Adjustable Arm Tablet Stand
Tablets are great for surfing the web and can help hours pass like minutes. But anyone who has held one for a while will know the 'arm ache'! If you find yourself wishing you could go hands free with your tablet then this is the project for you. Why buy an expensive solution when you can make one yourself? (way more fun)
In this project we'll show you how to create your own portable DIY stand by repurposing an unloved lamp. It's super portable too, so you can move it around the house as you need it — by your bed, at your desk or with your morning coffee :) It's time to give your arms a rest.
Kit List
An table lamp with an adjustable arm
Wire clippers
A tablet case
Screwdriver / hex key (to dismantle the lamp)
STEP 1: Video Overview
STEP 2: Finding the Right Lamp
- You will need a lamp that has an adjustable arm, to give you free movement of the tablet when it's clipped in.
- An added bonus (but not essential) is finding a lamp with an adjustable/twistable head — this will give you the choice of using your tablet in both landscape and portrait modes while it is clipped in.
- For this project we rescued a Forsa IKEA lamp that we had sitting unloved and underused in the corner of Sugru HQ. Turns out it's perfect for this!
STEP 3: Cut the Plug Off
Once you've found the right lamp — first things first, remove the lightbulb and cut the plug off the cable to be safe.
This will also make it easy to remove the full cable later on.
STEP 4: Remove the Light Shade and Socket
- Unscrew the fittings on the head of the lamp using a screwdriver / hex key.
- Remove the light shade completely.
STEP 5: Cut Off the Socket and Remove the Cable
- Cut the cable to remove the light socket piece and remove the remaining wire.
Pull the remaining cable through the frame of the light's arm to remove it completely.
STEP 6: Open Your Pack of Sugru
Now that you should be left with the core structure of the lamp, find a suitable surface that you can attach the tablet case to.
For this project we applied one single use pack of Sugru to the black circular piece of plastic.
- Cut open a single use pack of Sugru and roll it into a ball before applying.
- Roll the Sugru into a thin sausage.
Lightly press the Sugru sausage onto the rim or surface of the part of the lamp you want to attach your tablet case.
Top Tip: If you're lamp doesn't have a suitable flat piece to attach your case to, don't worry! Sugru is mouldable glue so you can use it to fill weird gaps. So chances are you can attach your tablet case to most odd shaped pieces! Here's a short video to help.
Head over to our Tips Page for more videos from the Sugru Guru :) Or send us a photo on twitter of the lamp you want to use for this project and we'll help you out :)
STEP 7: Attach the Case
Top Tip: if you don't have a rotational head on your lamp, this is when you'll need to decide if this is for movies (landscape) or surfing the web (portrait!)
- Line up your tablet case in the orientation you choose, making sure it is straight and centred.
- Press down firmly and hold in place for a few seconds to make sure the case makes a good contact with the Sugru.
STEP 8: Leave Your Stand to Cure
That's it. Now just leave your stand somewhere safe for 24 hours while the Sugru cures and your new hands free tablet stand will be ready to go the next day.
Top Tip: If you're doing this for a larger tablet and the case is heavier, you may want to use some tape to keep it in place while the Sugru cures. Here's a short video to show you some techniques for leaving your Sugru to cure.
* Just got a great improvement suggestion by Ironsmiter in the comments:
"You may also need to add some weight to the underside of the base. It is designed to safely hold a featherweight light bulb, and a sheet metal reflector, not a multi pound tablet. A 2 or 5 lb barbell weight would probably fit inside the base, and work quite well to keep it from tipping over and smashing your tablet."
If you've done a similar project or end up doing this project yourself, we'd love to see your versions. Share a photo on Twitter or drop us an email at fix@sugru.com.
Look out for more projects from us this month, we're looking at ways to make the most of your space at home — including 16 ways to hack your furniture with Sugru.
And as always, thanks for being part of the Sugru community :)
61 Comments
N3crojoker 9 years ago
projectsugru 9 years ago
it happens to us all, eventually ;)
jriddles sheffler 9 years ago
I think I need to makle one of these for my 91 y/o mom. She loves her iPad, but holding it is really hard for her, and her eyesight isn't great. This would allow her to be able to keep up with her social media and mail... not to mention the crosswords! Great insturctions!
Hey jriddles sheffler your mum sounds completely awesome! Maybe a you could do something using this kind of flexible lamp arm? might be easier to move for your mum. Let us know if you do the project, we;d love to see http://www.ikea.com/gb/en/catalog/products/00152461/
BobE10 5 years ago
SalvadorM10 8 years ago
In case you do not know you can actually use the cable to transform it into an usb charger for the table while holded. I do not know if we can cite anothers projects here so I keep the information. I think taht you can find it in Google. Great project by the way.
jad51 9 years ago
That is awesome think i will have to make one of these, but reading your comments my mum will probably want one too :)
electro32 9 years ago
puggirl415 9 years ago
This is neat. Because I do a lot of my tablet viewing in bed I'd love to figure out a way to mount it to the wall. Then I could move it to the side when I go to bed but still use it there.
ah yeh nothing beats a bit of Netflix in bed! you could try something like this that Sugru-er Vikas did http://bit.ly/1Av3XLO
Thanks for the link. That looks like a great way to work it out. I wish I had a head board on my bed but I'm confident I can work around that problem:)
gunnlaugursig 9 years ago
Great idea! :-)
thanks gunnlaugursig thinking of trying it yourself?
gravityisweak 9 years ago
An excellent idea! It would also be great to be able to adjust the height to your face while using a wireless keyboard. I like the suggestion about including a charging cable too. I'd also like to add that if you have to choose between landscape and portrait, landscape is the best choice. Even web browsing looks better in landscape (don't we all browse in landscape on the our computers and laptops?)
whoa! that's so true gravityisweak, we never really thought about that. Minds kinda blown right now :)
ironsmiter 9 years ago
leave the cord intact and in place, but still remove the lamp socket.
Wire the cord end (where the socket used to be) into a replacement female plug (from a hardware store, usually used to fix extension cords). Plug your tablets charger into the outlet, and away you go!
tomatoskins 9 years ago
That's exactly what I was thinking! Definately be able to charge it while on the stand.
yep 2.0 :)
Yup, alternately you may be able to add some sort of clamp depending on where you will be using it. Or even bolting it down if that's what will work for you.
