Introduction: Create an Applescript/Arduino Alert Flag.
Have you ever felt like the mail sound on your Mac just wasn't enough? Simple sounds and alerts just don't cut it for you? You want something more apparent and rewarding? If so, this is the Instructable you've been looking for.
In this Instructable, I'll show you how to hook up your Arduino to your Mac and throw up an actual flag when the alert of your choice occurs. In our example, we'll be doing an email alert, but you can use AppleScript to call this when almost anything happens.
I've created a little Instructables flag to go off when I receive comments on my instructables.
Let's get started!
Let's get started!
Step 1: What You Need
Hardware:
An Arduino: I know at least that the Duemilanove and the Diecimila will work. I don't know if older board versions will work.
A Flag: I made an instructables flag to alert me when I get instructables comment.
A 47 Ohm resistor: This is to prevent the Arduino from resetting at the close of a serial connection
A Servo
Wires to connect the Arduino to the Servo. My wires were a bit longer than needful.
Software:
Tod Kurt's Arduino Serial C code. Tod put this code up which makes it tremendously easy to communicate with the Arduino. Files included here. For more info look here:
http://todbot.com/blog/2006/12/06/arduino-serial-c-code-to-talk-to-arduino/
- Arduino Code
- Run Flag Applescript
A Servo
Software:
- Arduino Code
Step 2: Setup the Arduino
We need to get the physical side of this equation set up first.
Out of the Servo, There are 3 wires: Voltage, Ground, and Control. In this setup, we're plugging those into 5v, Ground and Pin 9.
Also, we're going to put a 47ohm resistor into the 3v3 pin and the reset pin. This will prevent the arduino from resetting every time there's a serial connection closed. This was a real pain for me to deal with early on, I'd written the software to handle the reset with a delay, but it wasn't ever working the way I wanted it to. Resistor solves that problem easily.
Note: According to the source I got this from, the Resistor causes an excessive 20mA current in the Arduino when the reset button is pressed. The person who tested it said it's outside of specifications, but still worked. Avoid resetting the Arduino when you have the Resistor is connected.
Software
Load the included software onto the Arduino. Make changes as you see fit. Essentially, you're sending a 0 or a 1 to the arduino, and it's going to turn the flag up or down based on that.
Software
Step 3: Setup the Servo & Flag
Tape Flag to pole.
Tape pole to the servo
...Pretty simple.
...Pretty simple.
Step 4: Setup Software Communication
First, you'll need to compile Tod Kurt's Arduino serial communication script. This is super easy.
Open up the terminal and navigate your way to where you have the arduino-serial.c file
Type in the following:
gcc -o arduino-serial arduino-serial.c
Once it's done compiling, type:
./arduino-serial
and it should print to the screen usage information.
Let's test out our Flag. In the terminal, navigate to where your newly made arduino-serial script and type in the following:
./arduino-serial -b 9600 -p /dev/tty.usbserial-A4001lGx -s 1
You'll need to substitute your Arduino's serial port. If you're not sure what this is, go into the Arduino software, and look under Tools->Serial Port. The order is important here. The -b is baud, and must be set before the port (-p) is set. -s is the message to be sent.
This should raise the flag, You can lower it by changing the "1" at the end of that line to a "0"(zero)
Once that works, the next thing is to setup the associated AppleScript. With this Applescript, you're going to have to tell it where everything is. For ease, I stuck everything in the same spot, namely: ~/Library/Scripts/ , of course you can use whatever you'd like.
Once you've got your Applescript setup, give it a go by pressing that big green "run" button at the top.
One more thing and we're set. Now we need to setup Mail.app to run the Applescript.
Open up Mail and go into the preferences.
Select Rules
Add a Rule
In the rule, set the conditions as you like. For me, I've setup the rule to have the "from" address contain "instructables.com", so it will fire when I receive anything from Instructables.
You're finished! If you have a method of testing it out, give it a shot.
./arduino-serial
Select Rules
Add a Rule
Step 5: Final Thoughts
You don't have to use Mail.app to take advantage of this, obviously. You can fire the script from any application that will access Applescript, including the Finder.
Windows users: I'm not familiar enough with Outlook to know if you have ways to triggering script execution, but I imagine someone here would have no problem figuring it out.
Because of the way Applescript is executed, the delay in the script will stop everything from happening while it waits. I haven't explored fixing this yet, but I imagine it would be done on the side of the Arduino, rather than the Applescript. For instance, send two parameters to the Arduino: The up/down bit, and a duration...
I hope you've enjoyed the Instructable. I put it together to see if I could figure out a little bit more about interacting with the real world from the computer world.
