Introduction: Creating Bumpers for a Robot
In my grade 11 computer engineering course, we were given the task to make our robot go through a maze. In order to control if it goes straight, turns left or right we were asked to make bumpers. This way if the robot touched the wall and it hit the right bumper, the robot would turn left and if it hit the left bumper the robot would turn right. So essentially our task was to create a bumper that is able to be pushed in to allow to turn and I also need to come back out so it doesn't keep turning on a loop. However, setting up a bumper also requires you to set up a code and a circuit in order to get your bumper running. Follow the following steps to learn how to make your very own bumper for a robot.
Step 1: The Circuit
In order to get the bumpers to work , you have to create a circuit on the breadboard on the top of your robot.
( follow the picture above to achieve 2 bumpers)
Materials Needed
- 2 small led lights (to ensure your bumpers are working)
- 8 wires
- 2 brown-black-yellow resistors
- 2 red-red-brown resistors
Some things to keep in mind
- The Vss is the "ground" there for it is equal to zero and the Vdd is equal to 1
- When the circuit is running the value is 0 when it is not running the value is 1
- The flat side of the led is negative and the other side is positive
Common Mistakes in Circuits
- LED is the wrong way
- The LED, resistor and wire are not lined up in the same column
- The led doesn't work anymore
Step 2: The Code
The Code :
' {$STAMP BS2}
' {$PBASIC 2.5}
LBump PIN 11
RBump PIN 10
LMOTOR PIN 15
RMOTOR PIN 14
RFast CON 650
LFast CON 850
RSlow CON 700
LSLOW CON 800
MStop CON 750
RFastRev CON 850
LFastRev CON 650
RSlowRev CON 800
LSlowRev CON 700
MLoopC VAR Word 'For..Next Variable up to 65000ish
DO
GOSUB Forwardfast 'go forward
IF IN10 = 0 THEN ' if the two wires in input 10 are pressed then turn left
GOSUB TurnLeft90
ELSEIF IN11 = 0 THEN 'if the two wires in input 11 are pressed then turn right
GOSUB TurnRight90
ENDIF
LOOP
TurnRight90:
' Subprocedure to Turn 90deg Right
HIGH 1
LOW 0
FOR MLoopC = 1 TO 22
PULSOUT LMOTOR, LfastRev 'move forward one pulse
PULSOUT RMOTOR, Rfast ' using pins and constants
PAUSE 20
' 20mS allows robot to move ' before NEXT pulse
NEXT
RETURN
TurnLeft90:
HIGH 0
LOW 1
PULSOUT LMOTOR, Lfast 'move forward one pulse
PULSOUT RMOTOR, RfastRev ' using pins and constants
PAUSE 20 ' 20mS allows robot to move ' before NEXT pulse
NEXT
RETURN
ForwardFast:
' Subprocedure to move the robot forward one square fast
FOR MLoopC = 1 TO 70
PULSOUT LMOTOR,
LFast PULSOUT
RMOTOR, RFast
PAUSE 20
NEXT
RETURN
Brief Overview
The purpose of this code is to program the robot to turn left when the right wires ( bumper) is pressed and turn right when the left wires ( bumper) is pressed.
What does the code mean?
Well before I answer that question you should be familiar with what some of the codes used in this program mean.
GOSUB - so sub stands for go to subroutine ( the subroutine must be identified in your code)
ENDIF - used to end multiple lines IF command
_________________________________________________________________________________________
explaining the meaning behind the code.....
DO
GOSUB Forwardfast
- Is telling the robot to go forward right when it is turned on
IF IN10 = 0 THEN
GOSUB TurnLeft90
- is saying that if the two wires in input 10 ( the right bumper) touch then the robot will turn left at a 90 angle.
ELSEIF
IN11 = 0 THEN
GOSUB TurnRight90
- is saying that if the two wires in input 11 ( left bumper) touch then the robot will turn right at a 90 angle.
TurnRight90:
HIGH 1
LOW 0
PAUSE 20
NEXT RETURN '*********************************************************
- this is an example of a subroutine which is used so you dont have to repeat the same long code over and over again. this way your code looks neater and more put together.
- the high 1 / low zero means that when the robot turns right ( the left wires touch) the led turns on, this way you know everything is working.
Step 3: The Bumpers ( Materials Required)
To make the bumper, you will need...
- 4 Popsicle sticks for the main structure and 2 Popsicle sticks to mount the bumper onto the robot
- 4 pieces of a sponge
- 4 paper clips
- so aluminum foil
- 4 wires ( to connect to the breadboard, explained in step 1 about the circuit)
- hot glue gun and glue sticks
- masking tape
Step 4: Assembling the Bumpers
To make one bumper, take 2 popsicle sticks and cut the rounded ends off ( like marked in the 1st picture). These popsicle sticks will act as the top and bottom of your bumper. In order for the wires to touch and un-touch right after, a sponge is required. Take a sponge, and cut off 2 tiny squares ( like in the second picture shown above). Then using a hot glue gun, take 1 popsicle stick and glue 1 sponge square on the left side, and one sponge on the right side( use the 3rd picture as a reference). Then take 1 wire and wrap one end of the tip of the wire with some aluminum foil. Place the wire on the middle of the popsicle stick and secure it with a paper clip. Repeat this step with the second wire and popsicle stick. Last glue the popsicle without the sponges, to the popsicle with sponges ( like shown in the 3rd picture above). Now your first bumper is complete
Repeat this whole process a second time to make a second bumper.
To add the bumpers onto the robot, take one popsicle stick and glue it onto the bottom of the bumper. Angle the left bumper towards the left side, and angle the right bumper towards the right side. I stuck the bumpers on with masking tape. ( picture number 4 is the completed bumpers, attached to the robot).
