Introduction: Creating Nano Technology
Nano Technology is the future of computers, technology, and electronics. So why not start now. Also please vote for this Instructable in the tech contest hosted by little bits, thank you
Step 1: Materials
Here are the materials:
Two 1 1/2 clip wires ( I made my own)
Two pen springs
aluminum foil
power source( car battery, electronic tester, wall outlet etc.)
One 1 ft. Tube
Syringe
Beaker
Sulfuric acid
Solutions containing sulfur and cadmium
Optional* High powered microscope
Two pen springs
aluminum foil
One 1 ft. Tube
Syringe
Beaker
Sulfuric acid
Step 2: Building the First Part
So the first thing you do is get your beaker. Then you screw an aluminum foil two inch square on to the beaker. And then you hook up the clip wires to the aluminum foil square. If you want you can also put a tube and syringe in to put the chemicals in the beaker
Step 3: Finishing the Machine
Then you cover the top of the beaker with aluminum foil(with the tube in it) and then you tape it down. You also hook up the syringe to the tube to add chemicals.
Step 4: Pouring the Chemicals In.
So then you take the beaker and pour sulfuric acid in it and then you give the aluminum foil a direct shock. Then you pour solutions containing sulfur and cadmium in and give it another shock.
Step 5: Finishing
So the only way to see your work is with A high powered microscope. Also the person that came up with this process is Saumil Bandyopadhyay, so you can look him up for more of his process.
Remember to please vote for me in the tech contest.
