Introduction: Creating a Charging Cable for Xiaomi XXQ01HM Trimmer
I had lost the charging cable of this trimmer and felt like this trimmer had more life in it.
The approach taken in building a charing cable can be reused for any USB powered device having such pronged charging port.
- The trimmer iself
- Suitable refills or cases to cover the prongs in the trimmer
- Old USB cable
- Glue stick (w or w/o gun)
- Cable protector (optional)
Step 1: Prep the Old USB Cable
- Cut out the end of the USB cable (USB B or C) and split out the 4 wires (if USB 2.0)
- Trim off the blue and wite data wires- these are not needed.
- Strip the red (+5v) and black (gnd) wire with sufficient lenghts (keep excess for now)
Step 2: Prep the Connector and Test for Charging
- Place the clean refil ends or the casing that you'd be using, cut with an additional 0.5cm excess
- Repeat for both the prongs
- Add hot glue around the casings to make the positions fixed
- For this trimmer, the polarity is as below, thanks to inputs from a fellow DIY'r (Polarity.jpeg)
- Push the stripped wires in and check for charging (Charge test.mp4)
Step 3: Finalize the Connector
- Once the charging is tested, add pieces of sleeve or so to jam the wires in position, add some glue
- Add a blob of hot glue to make the connector more robust
- Add a cable protector to make the entire cable more robust
- Mark the polarity on the connector and the trimmer as there is no facility for yoke poke here- I did that with some nail polish
