Introduction: The Arduino PS/2 Keyboard Smart Interface
The Problem:
Many of my arduino projects need keyboard data entry. The library needed to process keyboard scan codes is hefty, not leaving much space and cpu time for the "real" project.
The Solution:
Off load the scancode processing to another Arduino, that can then pass characters to a host microcontroller (Arduino, Pic, Basic Stamp, etc.)
Welcome to the world of smart shields!
To start this project you will need two Arduino boards and a PS/2 Keyboard Jack. At the end, you can build a DIY Barebones Arduino to host the keyboard interface and code.
The Solution:
Step 1: Reading the Keyboard Scans
For this step you will need a ps/2 mini din, full size (xt) din, or usb jack (only some usb keyboards are backwards compatible). Connect it to an Arduino using 4 wires, for Interrupt (Clk - D3 on the arduino or pin 5 on the atmel328P-PU), Data (D4 or pin 6) , +5v, and Gnd.
Download the keyboard library and upload the TX sketch to the Arduino. Check to see that you are reading the keystrokes in the serial monitor.
The schematic shows D5 as the TX port to the host Arduino, but we will be using D10 (Atmel pin 16) eventually. Just make sure you edit the code for whatever digital pin you choose to use.
Step 2: Receiving the Characters on the Host Arduino
On your second Arduino (or whatever your host controller is), you need to read the serial data from the smart shield. This example will show the code for the Arduino. We are using pin 10 to receive the data. RX Code is available at
http://arduinotronics.blogspot.com/2013/09/arduino-keyboard-shield-part-3.html
Open the serial monitor for this Arduino, and you should see the keystrokes being transmitted from the smart shield. You may have to press reset on the smart sensor to get everything to sync up.
Step 3: Build the Smart Sheild
Now that you have everything working, it's time to transfer your project to a barebones Arduino. This smart shield should cost you about $20. For instructions on building a barebones Arduino, see
https://www.instructables.com/id/The-Embedded-Arduino-building-an-Arduino-into-a-p/
Parts:
Barebones Arduino Kit or second Arduino board
PS/2 Keyboard Jack
PS/2 Keyboard Breakout
Protoboard
I recommend you put your Arduino chip (Atmel 328P-PU) in a socket instead of soldering it. This way you can program it in your main board (Arduino with a socketed Atmel 328P-PU) before inserting it into your barebones board, eliminating the need for a programming interface.
Parts:
PS/2 Keyboard Jack
Protoboard
