Introduction: Creepy Formerly Decapitated Necklace
It is so nice that the mad scientist reattached your head after his experiments... he just doesn't seem very proficient at plastic surgery.
Guess it's better than being headless...
Fun, simple necklace I designed for a Halloween party. Easy and affordable to make.
(Entry in the play with clay contest, vote if you like it!)
Step 1: Stuff
Tools & Supplies:
Black Sculpey Polymer Clay
20 gauge Red Copper Wire (in the jewelery making section)
Cookie sheet or glass bake ware
Dinner Knife
Scissors
Device of flattening (I used a highlighter)
Waxed Paper (or silicon baking mat if you have one)
Optional:
Round nose pliers (or other needle nose pliers)Clear Nail polish Clear acrylic finish
Step 2: Knead & Roll
I used one "section" of the package for this project and it was more than enough to make a necklace for myself and my minion (toddler)
Knead that ball of clay for 2 minutes, until it is nice and soft and flexible.
This would be a good time to preheat your oven to 275 degrees.
Now lay out your baking mat, or sheet of waxed paper
Roll the clay out into a snake, then roll flat with your Highlighter (or whatever device you have chosen)
I try to aim for the width of a quarter and about that thickness.
Don't worry about being perfect, little deviations and deformities just make it more fun.
Step 3: Slice and Dice
Once your clay is all flattened out just start cutting strips along the length, maybe 2 quarters wide.
Use the knife to gently lift the clay off the rolling surface.
One at a time place the strips on top of each other in an"X"shape and press lightly on the center.
Step 4: Stabby
Once you have a happy little army of X's unroll a piece of copper wire and cut it, about 2" in length, pull it straight.
Use your little wire needle to stab a hole through your little X's
Stab the X where the seam between the clay strips meats from one side to the other.
Give the wire a little wiggle to clear excess clay but not enough to make a huge hole or it will be difficult to control the X in the finished project.
Line up the X's on your wax paper coated baking sheet as you finish each one or just toss the silicone mat right on the cookie sheet.
Step 5: BAKE.
Throw the cookie sheet in your preheated oven
Bake for 15 minutes at 275 degrees
While you are waiting measure out your necklace wire, just put it around your neck (or your minions neck) and bend where it meets, make sure to leave some slack for bending ends to latch and for when the X's are on the wire. (you can always cut more off but you can't put it back once it is cut)
*BEEEP!*
Now go over to the oven (with oven mit equipped) and pull out the X's and set them aside to cool.
Step 6: Thread Your X's
Now that your X's are all cooled grab your wire, and bend one end so your X's can't escape and start beading.
Thread your X's on the wire and eye the spacing to what you like, once again don't worry about perfection, they can be adjusted later.
Now put the necklace up around your neck and line up the X's, take the loose end and loop it through the hooked end and bend it where it fits comfortably.
Trim off any large amount of wire but leave enough to make an adjustable hook.
If you have round nose pliers use this opportunity to bend the ends to make tiny loops on the ends to prevent stabbing or cutting your neck. This can be done with your fingers or any other pair of needle nose pliers you have on hand. Round nose pliers would accomplish the neatest finished appearance.
Now just bend back the wire to make a hook.
Do not twist the wires together, hammer the hooks or secure with a clasp, we do not want to have an actual decapitation...
This simple double hook will unbend if snagged, before injuring your neck, SafetyFirst!
Step 7: Optional: Clear Coat
If you like shiny things... find yourself a bottle of clear nail polish clear acrylic finish and a sheet of waxed paper
It has been suggested to me by the polymer clay pro's to avoid using nail polish, try and find some clear acrylic paint at the craft store, or another clear water based finish for best results.
I put a dab on the seams on the back of the X's just for a little piece of mind support, then flipped all the X's and painted the outside surface with one thick coat, making sure to get into the seams.
Make sure if you do this step you wiggle the X's a little to keep them from gluing themselves to the wire.
Now just let it dry.
Step 8: Equip
Now just hook your snazzy new necklace around your neck and adjust the X's to your comfort.
And look, now your head has been successfully reattached!
Add a little white powder to your face & neck if you are feeling a little undead and rock your necklace like a zombie!
Second Prize in the
Play with Clay Challenge
4th Epilog Challenge
Halloween Props Challenge
50 Comments
10 years ago on Step 6
here are my pics
Reply 10 years ago on Step 6
Looks great! :D
10 years ago on Step 7
Never use clear nail polish or any other solvent based finish on polymer clay. It will literally leave the surface tacky and never dry up. You can use a water based product, ot even the paste wax like Minwax to put a gloss on polymer. I have been a polymer clay artist for almost 30 years, so I know this from trial and error. This is a great project, though.
Reply 10 years ago on Step 7
Mine dried well, pretty quickly too and the finish seems to be holding up well, but that is a good suggestion, this is the first time I have attempted to clear coat any polymer clay project, maybe I got lucky on that.
I have heard of Polymer clay artists using Future floor polish to give their finished projects sheen. Wonder if that would make the items tacky?
Future worked well, but no one seems to be able to find it anymore. I haven't looked because I use Varathane, which is a water based polyurethane coating for wood. However, I think that it's either going out of business, or the stores around me are not carrying it anymore.
As for the nail polish, you might not find it to be tacky until it's hot outside, or you might have something that is water based. They don't put that on the label, but perhaps the companies are getting wiser about fumes. I don't think they make water based nail polishes, but I'm really not sure. If your project starts to get tacky after a while, you can put a water based coating over it, and it will seal. Unless you have fibers stuck to it, there's no need to sand it first.
Future floor wax is now lab led as pledge floor wax with future shine.
I got a bottle of it at Lowes...it's enough to last me the rest of my lifetime :)
10 years ago on Step 8
I did this and it was so much fun!
And the little guy is ADORABLE! haha.
My niece and I had alot of fun pulling pranks on my uncles and aunts with a little fake blood we found.
Just remember to not use any pan or baking sheet for sculpey that you plan to use for food later. PVC clay can make you very very sick> I use wax paper so I can toss it after I'm done.
You should switch to parchment paper for oven stuff. Wax paper isn't really rated for baking, as the wax can melt or evaporate in the oven and still leave you with PVC on your pans.
this is awesome. i made it this yr, and creeped out one of my freinds. i use a piece of tin foil for all oven bake clay projects and it works very well.
Congrats on the win! I love this project! I can see some stitched necklaces in my future.
Great stuff! I'd recommend slightly curving the tips of each "X" before baking. That way, when you have the necklace against your skin, the ends of each "X" will indent the skin slightly, giving more of an appearance of being real stitches actually going into your skin.
I know what I'm doing for Halloween now....
Reply 10 years ago on Step 8
I did this with mine. And I made my x's out of rounded segments as opposed to flat, with tapered tips. The effect is most excellent and I am very pleased. Sadly I cannot find my camera.
wow cool and really simple
Hey! i've seen and favorited your project on CutOutandKeep! LOL Good job on being a finalist!
Oh wow! I'm doing a bus trip to Salem, Mass on the 29th. I'm a red hatter and have to make a costume. I've made my hat and costume, but this will ad the final touch! Thanks
good luck.. great Halloween idea
Simple and totally awesome!
