Introduction: Crispy Bread Aloo Tikka
Sitting at home in Covid times or having a day off from workπ???. Try out this new Indian recipe 'bread aloo tikka' πππin your free time. You will be delighted by its crispy saucy taste and hopefully it will enlighten your mood.
Let's begin
INGREDIENTS USED:-
# Bread(I used the smaller pack having 10 slices)
# 2 Big boiled potatoes or 4 smaller one would
be good enough.
# Flour (2 Cups)
# Curd/Yogurt/dahi (1Cup)
# 1tsp Salt ,1/2tsp Red chilli powder,1/2tsp
Indian masala (If you don't have
masala/spices you can skip).
# Aloo bhunjia (or Haldiram mixture).
# Finally some Cooking oil ,containers,fry pan
and sticks.
Step 1: Prepare Ingredients for Dough
Start by peeling of the sides of bread and keep it aside for a while.Take 2 cups of flour in a container. Add two Boiled potatoes,1tsp salt ,1/2tsp chilli powder ,1/2tsp Indian Garam masala & add some turmeric powder 1/4tsp(again if you don't have masala/spices you can skip them).Break four bread slices into small pieces and add it in the container.
Step 2: Now It's Time to Mix the Ingredients.
Start mixing the dough softly and add 1/2 cup water little by little.(mix it till the salt and chilli powder spread uniformly probably it would take 2-3minutes).
Once it's done it's time to make small spheres(tikka) out of it. This amount of dough would be enough to make 15-20 tikkas .(I made 18)
Step 3: Sticking the Bread.
Soak a bread slice in water then squeeze it by pressing it under palms.(it Is necessary to make the bread wet so it sticks to the surface of of spheres properly). Now divide the slice in two half's.Cover the tikkas with the halfed bread slices and press it properly and make it disc shaped (I personally preffered disc shape over the spheres but anyway you could leave it as spheres also, it won't make a difference in taste).
Step 4: Frying
Heat the oil in any fry pan and Fry the tikkas on a low flame till it turns light brown colored. Once all the discs are fried make a small hole at its centre and insert the stick into it.
Step 5: Add the Toppings.
I added 4 tikkas on one spoon so I used 3-4 spoon of yogurt on it (you could add more or less as per your requirement but 3-4 spoon would give a better taste)
Add some Green chilli sauce,Tomato ketchup & the most delicious ingredient "Aloo Bhujia" and probably some salt and chilli powder.
πππ!!!Now you finally made it ,ππeat and enjoy your day with your friends and family.
If you like it leave a comment and share it with your friends.
On a Stick Speed Challenge
