Introduction: Crochet Easy Arcadian Rectangle Tablemat
Crochet Tablemats are a great way to protect your table as well to add a touch of elegance to your Dining Table settings. Crochet Tablemat are the perfect way to add a handmade style to your Dining Table. They are great to make at any time of the year. They make great House Warming Gifts. Even with the basic Crochet Stitches you can create beautiful textured Crocheted Tablemats.
Crocheted Tablemats are super customizable. You can make them in any size and shape. You can color code them to match any Home Decor or Holiday Season.
Today am sharing the pattern for Crochet Easy Arcadian Rectangle Tablemat. Its a simple and quick to make pattern. The Tablemat is made only with Half Double Crochet Stitches. The Half Double Crochet Stitches worked in bunches creates the lovely textured look.
Visit https://rajiscrafthobby.blogspot.com/2024/11/crochet-easy-arcadian-rectangle-tablemat.html
8/12 inches- Customizable to any size
Crochet Terms Used:-
US Crochet Terms
8 Ply Cotton Yarn
4 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 40 + 2 Chain extra for the Turning Chain.
This measures around 8 inches.
You can adjust the size by altering these stitches according to your requirement.
Start with any Multiple of 4 + 2 Chains extra for the Turning Chain.
Step 3:
Round 2:-
1 Half Double Crochet In the 5th Chain from the hook.
Skip 3 stitches.
4 Half Double Crochets in the next stitch.
Skip 3.
Repeat(4HDC,Sk 3)
1 Half Double Crochet in the last stitch.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain to make the Turning Chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge .
- Insert the hook into the 1st chain from the bottom.
- Yarn over and pull up a loop. You should have 2 loops on the hook.
- Turn your project and insert the hook into the first stitch.
- Yarn over and pull up a loop. You will have 3 loops on the hook.
- Lastly, yarn over and pull through all the 3 loops.
- This will make one Half Double Crochet.
Step 4:
Round 3:-
**This round we will be making the stitches only in the 4th Stitch of the 4 Half Double Crochet bunch.
4 Half Double Crochets into each of the 4th Stitch of the Half Double Crochet bunch.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain mentioned in the previous round to make the Turning Chain.
Step 5:
Round 4 Onwards:-
Keep Repeating Round 3 untill its Rectangle in shape or untill the size needed and weave off.
