Introduction: Crochet Embroidery Handbag
One of the best things about Crochet handbag is that they are a perfect solution for organizing and storing your thing. They are wonderful for keeping everything from hand towels.....toys.....your crochet materials and most of your other necessities.
This bag size is easily scalable to meet your requirements. To adjust the size, simply alter the chain stitch count at the beginning.
You are required the following materials -
- Any type of fiber will work but yarn would be best
- Crochet hook
- Embroidery tools
Step 1: Setting Up the Base
- Make a slip knot to begin.
- Chain 11.
- In the second chain from the hook, make one single crochet.
- Until the final stitch, single crochet in each of the remaining stitches.
- In the final stitch, make 3 single crochets.
- Work on the opposing side further.
- Until the final stitch, make 1 single in each of the remaining stitches.
- To finish the round, slip stitch over the top of the first single crochet.
Step 2: Repeating the Same Steps
- Chain 1 (Not Counted as s Stitch) In the same stitch, make 1 single crochet.
- Until you reach the turning 3 single crochets, make 1 single crochet in each of the remaining stitches.
- Make 3 single crochets and use a stitch marker to identify the second stitch.
- The increase would be made with this stitch in the following round.
- The next stitch will have 1 single crochet.
- In the following stitch, make 3 single crochets.
- Mark the second stitch once more with a marker.
- 1 Single Crochet should be continued in each stitch until the next turning 3 Single Crochets.
- Repeat the same action over here.
- Mark after 3 single crochets.
- 1 Single Crochet in the following Stitch (mark the center stitch).
- (Note the center stitch)
Step 3:
- Repeat step 2&3 until you reach the required size.
- Just Keep in Mind:
- Chain 1 (Not Counted as a Stitch, 1 Single Crochet in the same stitch) to begin each round.
- Identify each corner stitch.
- In the indicated corner stitches, make 3 single crochets.
Step 4: Flower Embroidery ( Optional )
- This step is completely optional so if you wish to do this step you can refer online designs of flower embroidery : D
- Also for making the borders I made the border using reverse single crochet.
- The Bag now has a Textured Finish as a result. Chain 1,1, and then reverse single crochet in the remaining stitches to begin the round.
- Similar to the regular single crochet, but with the hook inserted into the next stitch to the "LEFT" rather than the "RIGHT," you can produce a single crochet stitch there.
Step 5: Done
Congratulations guys you have done it : D
Thank you for watching !
