Crochet Pac-Man and Ghosts
Intro: Crochet Pac-Man and Ghosts
Pac-Man and his ghosts! This started as a project to just crochet Pac-Man. Then this expanded to making the ghosts, then to making the ghosts with movable eyes, and lastly to adding in covers to make the ghosts switch to dark blue. I am most pleased with how the ghosts turned out. Hope you enjoy!
STEP 1: Supplies
- Yarn (I used Red Heart yarn to get these results) (Yellow, Light Pink, Red, darker yellowish tan or gold, aruba sea, dark blue, black)
- Crochet Hook Size G/6 4.25mm
- Plastic Canvas Needle
- Brads (Brass Fasteners) (8)
- Black and White Felt
- White Thread
- Sewing Needle
- Good Scissors
- Hot Glue Gun
- Button (optional for tracing)
STEP 2: Making Pac-Man
Pac-Man is really simple. The main body is Yellow and his mouth is Black.
Body: (in Yellow)
- Magic Ring 5, ch 1, turn (I tried to do this with just chaining 2 and then crocheting 5 sc. into the second st. from the end, but this caused a big hole to show so I think a magic ring works better because it makes the stitches tighter)
- Skip first st., Inc across (10) ch. 1, turn
- Skip first st., [Sc. in next st., inc. in next] Repeat (15) ch. 1, turn
- Skip first st., [Sc. in next 2 sts., inc. in next] Repeat (20) ch. 1, turn
- Skip first st., [Sc. in next 3 sts., inc. in next] Repeat (25) ch. 1, turn
- Skip first st., [Sc. in next 4 sts., inc. in next] Repeat (30) ch. 1, turn
- Skip first st., [Sc. in next 5 sts., inc. in next] Repeat (35) ch. 1, turn
- Skip first st., [Sc. in next 6 sts., inc. in next] Repeat (40) ch. 1, turn
- Skip first st., [Sc. in next 7 sts., inc. in next] Repeat (45) ch. 1, turn (It might help later to keep a marker here)
- Sc. across (45) ch. 1, turn
- Sc. across (45) ch. 1, turn (It might help later to keep a marker here)
- Skip first st., [sc. in next 7 sts., dec.] Repeat (40) ch. 1, turn
- Skip first st., [sc. in next 6 sts., dec.] Repeat (35) ch. 1, turn
- Skip first st., [sc. in next 5 sts., dec.] Repeat (30) ch. 1, turn
- Skip first st., [sc. in next 4 sts., dec.] Repeat (25) ch. 1, turn
- Skip first st., [sc. in next 3 sts., dec.] Repeat (20) ch. 1, turn
- Skip first st., [sc. in next 2 sts., dec.] Repeat (15) ch. 1, turn
- Skip first st., [sc. in next st., dec.] Repeat (10) ch. 1, turn
- Skip first st., dec. (5) slip stitch closed and tie off
Mouth: (in Black)
- Chain 8, turn
- Sc. across (7) ch. 1, turn
- Sc. across (7), tie off
You will have to decide how long the mouth piece needs to be based on how big your Pac-Man's body ends up being.
To attach the mouth on the body, start at one corner of the black piece and one corner of Pac Man's mouth. I single crocheted around with yellow yarn. If you marked where you stopped increasing and started decreasing you should be able to match up the corners of the black piece easily to the corners of his mouth. To make it easier and make sure the piece attaches evenly, use paperclips to hold the mouth to his body. It will look like he has many lip piercings.
I put in some stuffing when I started to make it easier to grab him and then finished stuffing him before I finished crocheting him up.
STEP 3: Ghosts
I really like crocheting the ghosts. Especially the little ghost feet! You will need your Pink, Turquoise, Red, and yellowish Tan color yarns.
Body:
- Magic Ring 6
- Inc. around (12)
- Sc. in first st., inc. Repeat (18)
- Sc. in first 2 sts., inc. Repeat (24)
- Sc. in first 5 sts., inc. Repeat (28)
- Sc. in first 6 sts., inc. Repeat (32)
- Sc. in first 7 sts., inc. Repeat (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)
- Sc. around (36)*
- Sc. around (36)
- [sl. st., sc., inc. dc., inc. dc., sc., sl. st.] Repeat (48)
- [sl. st., sl. st., sc., inc. dc., inc. dc., sc., sl. st., sl. st.] Repeat (60) tie off
*Author Nina Tangled recommends on round 16 to stitch around in front loop only use the back loops to sew in the bottom piece
Ghost's Bottom:
- Magic Ring 6
- Inc. around (12)
- Sc. in first 3 sts., inc. Repeat (30)
- Sc. in first 4 sts., inc. Repeat (36) sl. st. closed and leave a tail to use to sew to body
STEP 4: Ghost Eyes and Putting Them Together
Eyes:
- Cut out 8 3/4 inch by 3/4 inch square pieces of black felt
- Cut out white circles about 1 1/4 inch in diameter (I used a botton as a guide) (Picture 4)
- Put a dab of hot glue on the head of the brad and stick it to the center of the back square. Do this for all of the back pieces. Hot glue is the best because it dries fast (Picture 5)
- Fold over and glue the four corners of the black square. (Picture 6)
- Fold over and glue the four corners you just created by folding over the other corners. Be very careful. I dabbed on a bit of hot glue and let it cool a bit, then pushed it down and held it with your finger, but you should of course not do this because you will burn yourself (Picture 7)
- Take one of your circles and cut out an "X" off to the side but not too close to the edge
- Stick the brad through the hole and you have your eye (Picture 9)
- I lined up the black brad with one of the front feet and went down about 8 rows. Make sure you like up the black brads together or the eyes will look odd (Picture11)
- Bend the back of the brads inside the body, but not right next to the body. (Picture 12) You want there to be a little room so you can move the white part of the eye.
Sewing Ghost Together:
Sew the circle to the bottom of the ghost. Not counting row 19, count up 3 rows and sew the circle to that row only sewing to the inside of the stitches so they cannot be seen from the outside of the ghost. I lined up the points of the circle (since it is more of a hexagon with the dips of the ghost feet (Pictures 18 - 21). It helped to turn the ghost feet out as in Pictures 22 and 23. Don't forget to stuff the ghosts.
Pictures 13 - 17 show how you can move around the white part of the eye to make the ghost look in any direction.
*Author Nina Tangled recommends dipping the feet of the ghost in glue to give them more stability so they don't curl.
STEP 5: Blue Ghost Cover
You need the dark blue yarn for the ghost cover. It is pretty much the same as the ghost except you expand to 42 stitches around, you crochet 3 extra rows of 42, and you add an extra double crochet (dc) to the center of each foot in each foot row.
Blue Ghost:
- Magic Ring 6
- Inc. around (12)
- Sc. in first 5 sts., inc. Repeat (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- Sc. around (42)
- [sl. st., sc., inc. dc., dc., inc. dc., sc., sl. st.] Repeat (54)
- [sl. st., sl. st., sc., inc. dc., dc., inc. dc., sc., sl. st., sl. st.] Repeat (66) tie off
Face:
- I used a button again to trace and cut out the yes for the ghost
- Draw out a squiggly mouth
- Sew on all your pieces
- Make sure the eyes are level with each other
Putting the blue ghost over a regular ghost:
- I turned the ghosts' eyes so they were looking up, this will make it so you won't damage the white part of the eyes
- Slip the blue ghost over the colored ghost (Picture 6)
- Once it is on, tuck up the colored ghost's feet so they don't show (Pictures 8 and 9)
- Done!
127 Comments
Nina Tangled 3 years ago
For the ghosts, on round 16 I do all the stitches around in front loop only and I use the back loops to sew my bottom piece.
Also, I dipped the legs in glue so they are steady because mine kept curling up.
Amazing pattern!
Penolopy Bulnick 3 years ago
Smangeri 5 years ago
Penolopy Bulnick 5 years ago
Let me see if writing it out helps. When you get to row 18, you should have 36 stitches around.
So for row 18 you need to: Slip Stitch - Single Crochet - Increase Double Crochet - Increase Double Crochet - Single Crochet - Slip Stitch - Repeat
Now you should have 48 stitches
Next is: Slip Stitch - Slip Stitch - Single Crochet - Increase Double Crochet - Increase Double Crochet - Single Crochet - Slip Stitch - Slip Stitch
Dose seeing it written out instead of all mashed together as abbreviations help at all?
I think I did this correctly, but the slip stitches in row 18 are not stitched into any of the single crochets from the previous row, but the ones in row 19 are. That's what I ended up doing, and it seemed to work.
Mbaumlmurray 10 months ago
Penolopy Bulnick 10 months ago
staciedillion 1 year ago
Penolopy Bulnick 1 year ago
SF Designer 1 year ago
Easy Paper Hacks 1 year ago
Stephcreates 1 year ago
Deanna Bair 2 years ago
Penolopy Bulnick 2 years ago
