Introduction: Crochet Round Box With Openwork Top
I crocheted this box as a gift. Perhaps for beginners it will be a little difficult, but the pattern turned out very beautiful.
crochet hook 2 mm
blue and white yarn 400 m/100 g
scissors
fishing line
scissors
fishing line
Step 1: The Top. 1st Round
Work in rounds. Crochet tightly. To make the top of the box more solid, I decided to add a fishing line. I crocheted so that the fishing line was inside the stitches.
Start crocheting with blue yarn.
You need to crochet 6 Magic Ring.
There is an excellent instructable Crochet Magic Ring Tutorial https://www.instructables.com/Crochet-Magic-Ring-Tutorial/
To keep the end of the fishing line well secured, first make a knot with the line, then align that knot with the knot of yarn, then crochet single crochets around the knots.
Step 2: 2nd Round
3 chains, 11 double crochets from Magic Ring center, slip stitch.
https://www.instructables.com/How-to-Foundation-Double-Crochet/
Remember to crochet so that the fishing line is inside the stitches.
Step 3: 3rd Round
3 chains, 1 double crochet. Then crochet 2 double crochets in every stitch.
Step 4: 4th Round
Fix blue yarn.
Attach white yarn: form a loop with white yarn, draw a loop through crocheting, crochet chain.
Next, crochet with white yarn.
3 chains, * start a double crochet, hook behind a stitch of the second round, crochet as with double crochet, but do not crochet the last two loops on the hook. Start again a double crochet, hook again behind the stitch of the second round, crochet as with a double crochet, but do not crochet the last three loops on the hook. Crochet all three loops together.
1 double crochet (together with fishing line) in the blue stitch of the 3rd round, 3 chains, 1 double crochet in the next blue stitch of the 3rd round.
Repeat after *. At the end, instead of 1 double crochet, make a slip stitch.
Step 5: 5th Round
1 chain, * 1 single crochet around the white arch, 1 double crochet behind two white posts, 3 chains, 1 double crochet lead in the same place, 1 double crochet lead behind the white arch and in a blue stitch. Repeat after *.
Step 6: 6th Round
3 chains, 5 double crochets in blue arch. * 1 double crochet under the first blue stitch of the previous round, but do not crochet the last loop on the hook, 1 double crochet under the blue stitch of the previous round without crocheting the last loop on the hook, then crochet all three loops on the hook. 6 double crochets in a blue arch. Repeat after *.
Step 7: 7th Round
1 slip stitch into adjacent arch, 1 chain. * 2 single crochets with fishing line, 1 double crochet in the middle of adjacent connected posts without fishing line, 3 chains, 1 single crochets without the fishing line in the same place in the middle of adjacent connected stitches. 1 double crochet in the same place without fishing line, skip two loops. Repeat after *.
Step 8: 8th Round
1 chain, single crochet in each stitch, 4 single crochet in every arche (together with 2 fishing lines). 1 slip stitch.
Step 9: Side Part of the Top
1st round single crochet in one loop of each stitch.
Further single crochet in each stitch.
Hide ends of the yarn.
The back of the top looks nice too.
Step 10: The Bottom
1st round
6 Magic Ring
2nd round
2 single crochets in each stitch.
3rd round
* 2 single crochets in one stitch - increase, 1 single crochet. Repeat after *.
4th round
* 2 single crochets, 2 single crochets in one stitch. Repeat after *.
5th round
* 2 single crochets in one loop, 3 single crochets. Repeat after *.
6th round
* 2 single crochets, 2 single crochets in one stitch, 4 single crochets. Repeat after *.
7th round
* 2 single crochets in one stitch, 5 single crochets. Repeat after *.
Continue crocheting in the same way, adding increases accordingly.
Check if the diameter of the bottom part matches the top part.
6 Magic Ring
2nd round
3rd round
4th round
5th round
6th round
7th round
Step 11: The Side Part of the Bottom
Crochet in the same way as the sides of the top.
