Introduction: Crochet Rug for Crochet Animal
Hello!
I will be showing you how to make a crochet rug.
It was hard to explain what I was doing without showing every single thing I did.
I hope you can understand you'll be able to understand what I was talking about.
Have Fun!!!!!
Step 1:
Make a magic circle then collect some string out the stick in the middle collect more string take it out of the circle collect more string out the stick into the two other circles in the stick collect more string out the string into the two other circles on the stick. Do it 11 times. Make sure you do two double stitches in one braid
Step 2:
Connect the two sides together. Go up by three again. Collect wool put it into the same whole and start putting your crochet in the top whole, the braid-looking thing collects work again, pull it out of the whole. Collect more wool, pull the wool through two collect more wool pull the wool through another Keep on going to all the braid-looking things are no more. You have to do two double stitches in each braid
Step 3:
You have to go up by three again and do two stitches in each braid all the way around, the same thing as step 2
Step 4:
These two is different it rotates. You have to do two double stitches in a braid then 1 double stitch in a braid. You have to keep on repeating that all the way around until there are no more braids
Step 5:
Then you have to dog 2 double stitches ( 2 stitches in one) then two single double stitches ( 1 stitch in the braid) you have to keep on doing that all the way around.
Step 6:
You have to do 1 double stitch (2 stitched in 1 braid) then 3 single double stitched (1 stitch in each braid). You have to keep on repeating those steps.
Step 7:
Then next row you have to have 4 single stitches and 1 double. The row after is 5 single stitched and 1 doubles. The next is 6 singles stitched and 1 double. Keep on going until you get the size you want
