Introduction: Crochet Shell Lace Earring
I love shell stitch is crochet. It has an elegant look. A shell in crochet is basically just a group of stitches worked into one base stitch.
These will be a simple and earthy accessory to your summer wardrobe.
This is a simple crochet pattern. It can be made in an hour and a good pattern to start with for the beginners.
The beads give a contrast to the crochet shell earring.
Step 1: Materials
Crochet Needle
scissors
Crochet Hook - 5.5-6.5 mm will be suitable
Yarn/Thick thread
Earring Hook
Jump Ring
Step 2: Begin
Ch 5. Join to form a circle.
Step 3: Round 1
Ch 3, 17 Hdc in the circle
Step 4: Shell Stitch (1)
Ch 3, 3 Dc in same space.
Step 5: Shell Stitch (2)
Ch 2 , 4 Dc in the next stitch.
Step 6: Shell Stitch (3)
Turn Sl St back to same stitch.
Sl St through all 4 Dc
Step 7: Repeat
Do the shell stitch in the chain loop.
Repeat the shell Stitch 1 time.
Step 8: Beads
Now cut the yarn at a good length enough to continue rest of the stitches.
Insert some beads into the yarn with the help of a needle.
Step 9: Insert Bead
Insert 1 bead and then do a Hdc.
The bead will appear at the back of the work.
Do the same 6 times.
You will have 6 beads.
Step 10: Finish
Insert a jump ring at the center of the first round.
Add a earring hook.
Your crochet shell earring is ready.
It is unique and fancy to see.
I hope you like it. :)
