Introduction: Crochet a Queensday Ring
What’s more Dutch for Queensday than a king or queen crown? That’s why I (the Knitbitch) decided to crochet a ring with a crown on-top. The ring itself is not too difficult, it’s placing the ring on-top without interruption the work that’s challenging. If you find that too difficult you can crochet the 2 as seperate pieces and sew them together afterwards.
Good luck!
Good luck!
Step 1: What You Will Need for This Project
some standard thin cotton SMC
crochet hook 2 and 3mm.
Choose your combination of yarn and needle so that your crochet will get really tight in order to make the crown stand-up.
Step 2: The Ring
Use hook 3mm, chain 16-18-20, check the size of the ring around your finger. Switch to hook 2 and join the ring by sc into the first chain, make sure that the ring isn't turned.
sc into every chn. make 3 rounds.
Step 3: The Crown
Here comes the tricky part.
Take a look at the ring from the top and imagine the crown that you are going to " raise" on-top of the ring. This helps you understand that you will need to crochet in almost the opposite direction than the work of the ring is directed.
chain 1, now sc1 in a bump in the middle of the ring, this will be the left extremity of the imaginary circle/base of the crown, chn 1. You have now "crossed" the width of the ring. sc2 in the chains that form the outer edge of the ring. chn 1, sc 1 in a bump int he middle of the ring, chn 1, sc 2 in the chains that form the opposite outer edge. This should form a neat circle of 10 loops.
sc into every chain and make 2 rounds.
Now the spikes. Check that you have 10 chains we will be making spikes in every 2nd chn, 5 spikes in total. sc in the 1st chain, chn 2, sc back into the first chain of the string, sc 1 back into the chain where you made the 1st sc. this forms the first spike. jump 1. sc into the next chain of the crown, chn 3, sc back into the 2nd and 1st chain of the string, sc back into the chain where you made the 2nd sc. jump 1. sc into the next chain of the crown, chn 4, sc back into the 3rd, 2nd and 1st chain of the string, sc back into the chain where you made the 3rd sc. jump 1. sc into the next chain of the crown, chn 3, sc back into the 2nd and 1st chain of the string, sc back into the chain where you made the 4th sc. jump 1. sc into the next chain of the crown, chn 2, sc back into the 1st chain of the string, sc back into the chain where you made the 5th sc. make 1 pull-stitch to close the loop, cut the thread and pull through.
Step 4: Finish and Decorate
work away the 2 loose ends with a needle.
Embroider sequins and beads to decorate.
