Introduction: Cross-Sectional Turkey
This Bendable is another installment in our exploration of volumes.
Check out our posts on revolved and helical volumes, as well. For this one we tried out Autodesk's 123D Make Software in order to split a solid model into cross-sections. And it's awesome! Check out our brief tutorial and try 123D Make for yourself. You'll end up with something that's a perfect base for papier mache, or a turkey leg covered in Spanx! Assemble with some clips and let us know how it goes!
Step 1: Gather the Necessary Materials and Tools
If you don't have access to a DIWire, the cross sections can be bent by hand using pliers and printouts of the files as templates.
Step 2: Print Some Clips
Cross-sectional volumes will require fixturing for perpendicular joints. So print some 3D clips and create your sections using Autodesk's 123D Make software...
Step 3: Import a Solid Into 123D Make
...any solid! It doesn't have to be a turkey.
(Really, it doesn't.)
Step 4: Slice the Model
Use "Interlocked Slices" to break the form up into cross sections.
Step 5: Export
Select "Get Plans" and then export as a DXF.
Step 6: Double Check the Files
Step 7: Bend the Cross-Sections
Step 8: Assemble
Assemble the cross sections with some 3D-printed clips. You can use more cross sections to create a denser wire-form or cover a sparse form in a different material.
