Introduction: Cruise Control 2.0
This project was creat by Nicolas Tanguay and Rémy Rodrigue for expo science 2013
Step 1: You Need
For this tutorial you need many thing. 1 Arduino,1servomotor,4 weels, 1 body car, 1 Webcam and all software
Step 2: Download All Software
First you need to install the Arduino and Labview. When is done download the plug-in vision and motion. After that download VIPM software for using the microprocessor. Once vipm search arduino and install it. Now we can begin to work.
links:
ViPM: http://jki.net/vipm
Labiew: http://www.ni.com/trylabview/f/
Vision and Motion: http://www.ni.com/labview/vision/f/
Arduino: http://arduino.cc/en/Main/Software
links:
Step 3: Download LIFA Base on Arduino
For communicate to Arduino with Labview you must upload the LIFA base on arduino. You can download the LIFA base in VIPM software. The name on this file is: LVIFA_Base.ino. DON'T FORGET TO DROP IN SKETCHBOOK.
For mor information you can follow the instruction on this web site: http://digital.ni.com/public.nsf/allkb/8C07747189606D148625789C005C2DD6
Step 4: Getting Vision Systeme
To begin we must to have a vision with webcam. In the block vision aquisition you can decide to chose the video format and many other option. In vision assitant you chose the matching pattern. The matching pattern is the maner for reconize a simple image. Exemple the line of the road. Choose 640x400 for display format.
Step 5: Situate the Road Line
The next step is to find the image localisation (matching pattern). When the match pattern is locate we must find the cartesinne localisaton X,Y. We just need the X. And find the position in the red square. Use the two diagonal. To find te center. After that you need to change the X for an angle: Exemple: 320=90
Step 6: Control Arduino
Now we must transfer the angle to Arduino. In this exemple the servomoteur was plug in digital PIN 8
Step 7: Add Condition
For the last step you can change the value 0 for 90. For better performance you can up the camera.
Step 8: Maybe You Can Have Probleme
If you have trouble with Arduino and the webcam you can try to put battery in the Arduino. For more information email me: here
