Introduction: Crysis Typhoon Minigun Prop
I built this model of a Typhoon minigun from Crysis 3 to showcase what you can do with an X-Carve CNC from Inventables. In this Instructable, I'll go over the techniques I used to build it and provide a link to the project and build files. If you don't have a CNC, no worries, you can still complete most of the model with basic shop tools like a jig saw, a mitre saw, and a router.
So let's get started!
Step 1: Pick Something Awesome
The most important part of building a replica prop is to go out and pick an awesome model. There are so many choices that it’s almost overwhelming.
Spend a lot of time studying reference photos to try to understand what the model looks like from the side, the top, and the front. Visualize each layer and how you could stack up pieces of wood to achieve the right effect. I use different sizes of MDF (1/2", 1/4" and 1/8") to add detail to the model.
Pick a good side photo and import it into a vector drawing program (e.g. Inkscape). Size the model to “real world” dimensions. Use a tape measure to measure your hand and figure out how long the grip needs to be or the stock. Once you get everything to scale, start tracing each layer. This is the most difficult and time consuming part of the build!
Step 2: Cut Out the Core
Materials needed for this step:
- 2 × 1/2" MDF sheets (30″ × 12″)
- Wood Glue
The basic construction technique involves cutting out multiple layers of wood and then stacking them up to form the details of the model. Start by cutting out the core from two sheets of 1/2" MDF. The rectangular area towards the front of the model is designed to save on weight. Be sure to keep that off-cut so that you can use it for other parts.
I used a 1/8" down-spiral bit on my CNC to cut out the core. You can also use a scroll saw or jigsaw (print the templates in paper and then glue them to the MDF with spray adhesive).
Glue the two halves together with wood glue. I use a roller to ensure that the glue covers the entire surface. Use clamps or place something heavy on the pieces so they adhere well. You’ll be surprised how quickly the wood glue dries (usually in less than 15 minutes.)
Step 3: Cut the Outer 1/2" Body
- 2 × 1/2" MDF sheets (30? × 12?)
- Wood Glue
Again using the 1/8" down-spiral bit, cut out the two “inner-outer” sections of the model. Be sure to make a mirror so the detail shows up on both sides. With a chamfer bit in a router, route around the grip and other marked areas. Safety first – use a push block! If you don’t have a router, you can do this with sand paper but it will take a lot longer.
Step 4: Cut Out the 1/2" Detail Pieces
- Scrap 1/2" MDF sheets (you should have plenty left over)
- Wood Glue
Now that the model shape is starting to come together, it’s time to cut out all of the 1/2" detail pieces that go along the front. Chamfer the edges as shown on the router. Again, experiment with a scrap piece to get the depth right. Carefully sand everything with 150 grit sandpaper. Sand everything, the body, the detail pieces, your fingers. Everything. Do this a lot. The more time you spend smoothing out the pieces now, the less time you’ll spend trying to get into tiny cracks and spaces.
Start by referencing the grip along the bottom of the model. Apply glue to the entire back side and clamp it into place or place something heavy on it. Be sure that it doesn’t shift! Once that’s dry, line up the heat-sink referencing the edge as shown. It’s a good idea to dry-fit all of the pieces at this point so you get a good idea of how they go together. Then, glue them down one by one.
Step 5: Cut Out the 1/4" Detail Pieces
- 2 × 1/4" MDF sheets (30? × 12?)
- Wood Glue
Now that the base of the model is complete, we can start adding in details. This is the secret sauce — building up pieces of MDF to make them appear to be one piece. Be sure to thoroughly sand and chamfer the edges on the router table before you glue them down — you won’t be able to do so afterwards. Use the original color-coded model for reference when attaching parts. Dry fit everything before applying wood glue!
Step 6: The Devil Is in the Greeblies!
- Imagination
- Various scrap pieces, dowels, washers, belt buckles, screws. craft foam
- Wood Glue
What the heck are greeblies? According to the Urban Dictionary, greeblies are: “The creatures that cats chase and wrestle with. Greeblies are invisible to humans. They are mainly nocturnal creatures, but have been known to be active during the day.” Actually, greeblies are all of those detail bits that make a model look more realistic. Drill a hole and drop in a screw. Cut off a dowel and attach it as a dial. This part is totally up to your imagination. Craft foam also works really well to add subtle detail.
Step 7: Prime and Paint
We’ve reached the finish line! Well, almost. Now it’s time to prep your model for paint. This is the Long, Dark, Tea-time of the Soul.
First, since MDF has a tendency to soak up paint, you have to seal the surface. I prefer ModPodge since it can be easily done indoors and covers nicely. I recommend sealing even before you lay down a primer. Second, grab some grey (sandable) automotive primer and carefully spray down the entire model. Don’t rush — apply light, even coats. You don’t want to have to sand out a run! Once the paint has fully cured, take it back inside and sand, sand, sand. Use 150 or 220 grit sandpaper and then follow it up with some 000 steel wool. This will leave a nice, smooth surface. Carefully look over the model for any imperfections. You can use Bondo or plastic wood putty to fill the blemishes and re-sand. This is why you take your time and sand pieces before application! Take it back outside and lay down another coat of grey primer. Rinse, repeat until you’re happy with the look. Read the paint can and ensure you follow the instructions for cure time before proceeding.
Step 8: Finishing
Finishing can take forever. There’s always one more thing you can do to perfect your model. In my case, I spent a couple of months agonizing over the finish.
I recommend laying down a coat of silver followed by orange (for the detail) and then flat black. Don’t worry about the finish — you can always add a coat of clear in whatever finish you want (e.g. matte, satin, glossy). I highly recommend Harrison Krix’s ebook on painting and weathering: Painting and Weathering for Props and Replicas Also, be sure to throw in some real screws — this helps to sell the effect. I found some cool buckles at Home Depot that while they didn’t match the exact design, did make the model look more complete. In the end, make sure you have fun with it! Use your imagination!
Step 9: Thanks!
Thanks for checking out my Instructable, I hope this inspires you to go out and build your own models!
Feel free to ask questions or check out my Facebook page for other models that I've build (or am in the process of building).
If you happen to have a CNC machine or a laser cutter, check out my project on Inventables that includes the SVG files.
