Introduction: Curly Fries | K'nex Ball Machine Element
Hello there again! Here I have for you instructions for my BRAND NEW motorised ball machine element!
Originally I wanted to make a lift from the standard spiral staircase turned diagonal however that didn't work out very well...So I turned it sideways and made an element! After many many fails and mistakes it is finally here. Good luck building it! ➡
Step 1: Step 1 - Frame
The skeleton of the element! The frame holds it all together.
1: Overview
2: Build this
3: Build this
4: Build this
5: Build this
6: Build this
7: Build this
8: Assemble
9: Assemble
10: Assemble
11: Assemble
12: Assemble
1: Overview
2: Build this
3: Build this
4: Build this
5: Build this
6: Build this
7: Build this
8: Assemble
9: Assemble
10: Assemble
11: Assemble
12: Assemble
Step 2: Step 2 - Motor
The Driving force of the element!
1: Overview
2: Build these
3: Build this
4: Build this
5: Assemble
6: Assemble
1: Overview
2: Build these
3: Build this
4: Build this
5: Assemble
6: Assemble
Step 3: Step 3 - Entrance & Guard
The entrance to the element and the guard stopping the ball going where it shouldn't. (If some pictures are missing here, I had a lot of trouble getting them to work)
1: Overview
2: Build this
3: Build these
4: Assemble
5: Assemble
6: Alternate view
7: Build this
8: Build this
9: Build this
10: Build this
11: Build this
12: Assemble
13: Assemble
14: Assemble
15: Assemble
16: Assemble
17: Assemble
18: Alternate view
1: Overview
2: Build this
3: Build these
4: Assemble
5: Assemble
6: Alternate view
7: Build this
8: Build this
9: Build this
10: Build this
11: Build this
12: Assemble
13: Assemble
14: Assemble
15: Assemble
16: Assemble
17: Assemble
18: Alternate view
Step 4: Step 4 - Exit
The exit track. It can easily be modified and doesn't have to stay as I put it.
1: Overview
2: Build this
3: Build these
4: Assemble
5: Assemble
1: Overview
2: Build this
3: Build these
4: Assemble
5: Assemble
Step 5: Step 5 - the Curly Middle
The fun part of the element itself! This is the hardest step to pay careful attention.
1: Overview
2: Build this
3: Build this
4: Build these (One is missing a green rod ON PURPOSE)
5: Assemble
6: Left end
7: Right end
8: Assemble
1: Overview
2: Build this
3: Build this
5: Assemble
6: Left end
7: Right end
8: Assemble
Step 6: Step 6 - Final Assembly
You finally get to make it! Good luck!
1: Overview
2: Assemble
3: Assemble
4: Alternate view
5: Assemble
6: Alternate view
7: Assemble
1: Overview
2: Assemble
3: Assemble
4: Alternate view
5: Assemble
6: Alternate view
7: Assemble
Step 7: Finish!
Yay! You took the time to actually make my element. Thank you for building it! Please tell me all about it in the comments and show me a picture! Now, if it doesn't work quite right here are some troubleshooting steps:
• Is the guard rail straight? If not it can easily catch the sides of the frame and make it jittery.
• Have you turned the motor on the right way? If not, well it isn't going to work! Push the slider right to turn it on and start the element.
• Is the exit aligned with the white snowflake connector? If not the ball may not exit correctly. You can achieve this with spacers or without them.
Step 8: A Few Fixes!
After recently getting 3 more k'nex balls (Now I have 4!!) I realised this element doesn't work when they stack together in the waiting area. I spent a long time trying to get them to go one ball at a time and finally managed it however you may have to play about with some of the placement to get it perfect. Here it is:
1: Overview
2: Build these
3: Assemble
4: Add these
If it is a bit jittery, replace the medium gear with a large gear. it will be slower but will work better
1: Overview
2: Build these
3: Assemble
4: Add these
