Introduction: Curved Nine Patch
Step 1: Supplies
Favorite Rotary cutter
Quilting ruler
7" finished Drunken Path Template
"You can use other size of the Drunken Path Template"
I started with 3 contrasting colors of fabric ½ yds each.
( There will be extra fabric left after cutting the pattern out.)
Step 2: Cutting 1
The measurements I am giving are for the 7" Drunken Path Template.
Iron and square your fabric.
Cut a 7½" strip from the selvage to the selvage cut 1 strip of each color which make 3 (strips 7½"X44")
Step 3: Cutting 2
(you will make 4 of these)
Tip In the second picture it shows you how to measure your other sizes of the Drunken Path Template.
Step 4: Cutting 3
Then you are going to cut the strip into 2"X7½".
(You need make 4 of these)
Tip In the third picture it shows you how to measure your other sizes of the Drunken Path Template.
Step 5: Cutting 4
Step 6: Cutting 5 & 6
Take that same yellow fabric and cut out 4 of template A.
Now take the green fabric 7½"X44 strip and cut out 4 of template B.
Step 7: Layout
Step 8: Sewing 1
repeat until you have 4 of them.
Step 9: Sewing 2
Repeat this 4 times.
Step 10: Sewing 3
Step 11: Sewing 4
Step 12: Finishing
make sure your points match and you are done !!!
You can make it as a centerpiece or make more then one block and make a bed size quilt.
Happy Quilting
& Kitty Approved
