Introduction: Custom Blu-ray/DVD Shelves (Beginners Guide)
Making Shelves doesn't have to be hard at all. So in this simple Instructable I'll be walking you through every step to make some shelves that can be easily customised to suit any size you have!
Materials
Wood - Standard DVDS are 140mm wide so the wood needs to be atleast that. But i would like my tv to sit on top so all my wood was ripped to 200mm wide.
Pocket Hole Screws
Pocket Hole Plugs
Wood Glue
Tools
Drill
Drill Driver
Mitre Saw (Hand saw will do if you have the patience)
Measuring Tape
Square
Pencil
Pocket Hole Jig
Corner Clamps
Clamps
Sander
Step 1: Cut the Wood to Size
I used some laminated panels that were 1800mm x 600mm x 18mm. I ripped these down to 200mm wide. I then used the mitre saw to cut them to the following sizes
2x 1500mm
2x 680mm
2x 1464mm
These dimensions will allow me to make a unit that has 4 shelves and a total size of 1500mm L x 716mm H x 200mm D
However these can be completely customised to any size you desire
Step 2: Drill Pocket Holes
I purchased the cheapest pocket hole jig I could find at the shops and then set it up. The drill has a depth stop and needs to be set up correctly which will depend on the thickness of your timber. 18mm is the thickness of the wood I'm using, so ill set the stop at about 89mm from the step of the bit
I clamped down the pocket hole jig and drilled 3 evenly spaces holes on each side of the wood. Its important to put these holes on the underside of the wood or at least the side that is the least visible.
Step 3: Attaching the Sides Together
Grab the corner clamps and take the time to align both the top and the bottom of the joint up until they are perfect and tighten them together,
Next loosen one side and slide the board back a little and add some glue.
Push the board back together and tighten the clamps
Screw the boards together with pocket hole screws
Remove the clamps and check the boards are square
Then its the same for the other sides to make the outside frame of the shelf
Step 4: Attach the Middle Shelves
Remeasure the inside dimensions of the shelf and cut the boards down to that size, mine were 1464mm.
Drill the pocket holes on the boards just like before
Then screw the shelves in at your desired height. I recommend cutting spacer blocks to help keep it at the height while attaching I chose 250mm from the bottom, and then 200mm on the next two shelves.
Step 5: Preparing for Finish
We are on the final stages now so i brought these little plugs to fill in the pocket holes and they need to be glued into place then cut down and filled with wood filler.
When that is done you can give the area a good sand, followed by sanding down the whole shelf unit up to 240 grit.
Step 6: Finishing
There is a million different ways to finish wood, from painting, staining, varnishing or even just waxing but i went with some linseed oil just to bring out the colour a bit then sealed it in with a cabinet makers wax. This just got applied with a paper towel and after a few coats it was all ready to be set up
Step 7: All Done
The shelves are all done and ready to be loaded up with whatever you are storing.
Hope you enjoyed this build and check out the YouTube video here: https://youtu.be/yHL8POMNrZw
Thanks Everyone!
