Introduction: Make a Custom IPOD/ Cell Phone Armband
Step 1: Materials Needed
Gather the following items:
1. IPOD, or Cell Phone
2. Vinyl Fabric (fabric from a child's raincoat, vinyl tablecloth, oilcloth, or purchase fabric from your local fabric store)
3. Clear vinyl (mine was up-cycled from a package that a quilt came in)
4. Sewing machine/thread (you can sew by hand if you have to)
5. Sew on Velcro/ or Hook and Loop tape
6. 1 1/2" metal rings- set of two.
7. 1 1/2" wide elastic (sold as "waistband" elastic in the fabric store)
Step 2: Trace IPOD/ Cell Phone
Step 3: Make Pocket Template
Measure and mark new lines 1/2" larger on all sides of your IPOD or Cell Phone outline. This is now the template for your front and back pocket.
Cut out template.
Lay template on your printed vinyl, and cut 2 pieces.
These are your Front and Back Pocket pieces
Step 4: Make Pocket Flap Template
Step 5: Stitch Pocket Flap
Turn Pocket Flap Right Side Out. Stitch 1/8" from edge around the outside.
Step 6: Front Pocket Window
Now add 3/4" to both the height and width of your front pocket window hole. These are the measurements to make your clear vinyl window template. Cut clear vinyl window using this template.
Step 7: Add Pocket Details
Finish the top edge of both the Front and Back pocket piecess by folding 1/4" of fabric from the right side, to the wrong side, and stitching 1/8" from folded edge.
Take Front Pocket piece, and place the clear vinyl window on the WRONG (INSIDE) side of the window hole. Place small pieces of tape in place if you need to secure it, then sew along the window edge. Trim clear vinyl inside after sewing if needed, and remove tape.
Step 8: Add Front Pocket Flap
Center 1 1/2" length of Velcro hook and loop tape on INSIDE (WRONG SIDE) of pocket flap, and stitch around the edges.
Step 9: Add Back Pocket Details
Center a 2" length of 1/12" wide Elastic Band to the Back Pocket, just below the hook and loop tape. Zig Zag stitch both the top edge, and the bottom edge of the elastic to the Back Pocket.
Step 10: Finish Pocket Details
Clip bottom corners and seam allowances to 1/8" , being careful not to cut too close to your sewing line.
Turn Pocket Right side out. Your pocket is done!
Now for the armband.
Step 11: Make Armband
Insert the 1 1/2" wide elastic band through both 1 1/2" metal rings, to create a 3/4" overlap. Stitch the elastic band edge with a zig zag stitch to enclose the metal rings. Zig Zag the seam 2 to 3 times for security.
On the opposite end of the elastic, zig zag stitch the raw edge, going back and forth over the edge with the zig zag stitch twice..
Step 12: Slide Pocket Onto Armband
Lay your armband down with raw edge on your left, rings on your right, wrong side up.
Slide the raw edge from Right to Left through the Elastic Strap on the Back Side of your pocket. Just like a belt, bring the raw edge of the elastic through both rings, then back through the outside ring.
Step 13: Get Going!
Ready, Set, GO!!!!
