A few other tips that could help in the proccess are these. 1: If you have regular griptape an easier way to take it off besided JUST peeling would be to get a heat gun or hot blowdrier and heat the tape up, The adhesive will release and will and make for an easy peel 2: When applying the griptape you could also get a stiff object like a yard stick or your skate tools metal edge and pres the edges of the grip tape to ensure that the edges stick properly 3: Also Gruffy mentioned if you can buy some spray grip tape online to ensure all around covorage for in between your tape design.
very very cool. Here's an idea that occurred to me while watching: you could stencil your grip tape first, then sand only where you need to sand. This would leave the middle of the board grippy in case you wanted to do some cross stepping or whatever.
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
8 Comments
onegiantmedia 8 years ago
Also if you want PRINTED custom grip tape, not custom cut, then check out the easy online grip tape designer on http://www.whateverskateboards.com/
TheHiddenHillSociety 12 years ago
Homemade longboards 12 years ago
macapaca9 12 years ago
gruffy 13 years ago
paperclip32 13 years ago
Matt Carl 13 years ago
zazenergy 13 years ago
