Introduction: Custom Menu Options Using Adafruit SSD1306 SPI Display and Arduino
I had this display sitting in my IOT box for a while now and today I decided to play around with it.
I came up with an idea to create a custom menu which can be used in all sort of electronic devices.
Step 1: Parts
1 x Breadboard or PCB
Couple of jumper wires
4 x SPST switches
4 x 10 kOhm resistors
1 x Arduino board (I've used UNO, but each one will do the job)
1 x Adafruit SSD1306 SPI display (Mine is not an original one. I've bought it from Aliexpress and I assume most SPI displays will work with their library)
Step 2: Software
You will need the latest Arduino IDE found here -> https://www.arduino.cc/en/software
Adafruit 1306 library -> https://github.com/adafruit/Adafruit_SSD1306
Step 3: Connections
Display
- Display pin MOSI to Arduino pin 9
- Display pin CLK to Arduino pin 10
- Display pin DC to Arduino pin 11
- Display pin CS to Arduino pin 12
- Display pin RST to Arduino pin 13
Buttons
- UP button to Arduino pin 3
- DOWN button to Arduino pin 2
- ENTER button to Arduino pin 4
- BACK button to Arduino pin 5
Pull-down resistors
You must tie each Arduino pin to GND with 10kOhm resistor in order for pin to be digital LOW while button is not pressed.
Step 4: Code
Here is the full source code.
Please reach out if you need any assistance or detailed explanation.
