Introduction: Custom Trunk Lightning
Since I have my car, one thing was upsetting me. The light in the trunk is just positioned in the wrong place. The stock light for the car (a OPEL/Vauxhall/Chevrolet Corsa ) is located in the lower left corner. If you put something in your trunk, all the light will always be blocked. In the photo you see the enhanced version.
- light from above
- and more lumen
Step 1: Rivet a LED Stripe to the Roof
I've applied a standard 12V LED stripe to a stainless steel sheet to spread the heat of the LEDs.
Step 2: Pull a Cable Through Your Car
Luckily for me, my car already had a light in the trunk even if it is useless. But at least I had the possibility to use the switched light to hock me on. Therefore I've pulled a cable through your car. From the roof over the left side to the stock light in the lower left corner.
Step 3: Other Cars Other Ideas
The car of my wive doesn't even have a light in the trunk, so there I've
pulled a cable from the interior lightning in the front to the back. Also I had to applied a switch to it, due to the lack of a switch. I just want to show some alternatives to you.
