Introduction: Custom Wood Wall Design
I used wood to create a unique wall design.  After working out the design on paper and determining all of the measurements,  I cut 1x4 pieces of wood into the individual pieces I would need.  In my case, there was 12", 15" 18", and  30" pieces.   It was over 100 cuts in all!  I then sanded each piece of wood to allow the stain to set and look better.  Then I stained each piece twice to get a dark espresso color.  Then came the finish.  I used Deft clear wood finish, a clear lacquer spray.  After the first coat, I used extra fine steel wool (0000) to buff each piece after which I applied a second coat.  When the wood was finally prepared, I used an air compressor and air gun (using 23 gauge, 1 3/8 inch brads) to attach the wood to the wall.  I used a measuring tape and a level throughout the nailing to ensure straight, even lines.  I am thrilled with the outcome.  It is a very unique home project that frames the television and gives the room a more modern and custom feel.
