Introduction: Customizable Knit Mittens
Mittens are a fast and useful project. This pattern allows you to customize them to your exact measurements and use whatever yarn you have lying around. This project can also be made with scrap yarn to make a funky striped pattern.
- 75-200 yards worsted weight yarn
- US size 7 circular needles OR double pointed needles
- Tapestry needle
- Scissors
- Stitch markers
Step 1: Step 1: Cast On
Using the long-tail cast-on method, cast on an even number of stitches that will fit comfortably around your wrist and upper forearm.
Step 2: Step 2: Wristband
Join the ends of the cast-on together to create a loop, making sure there are no twists in the row. Place a stitch marker at the beginning of the round.
Row 1: *Knit 1, purl 1, repeat from * to end of the round.
Repeat row 1 until the wristband reaches your desired length.
Step 3: Step 3: Making the Hand
When the wristband reaches your desired length, stop knitting in the 1x1 rib pattern. Begin knitting all rounds until the mitten reaches the base of your thumb.
Step 4: Step 4: Making the Thumb Gusset
When the mitten reached the base of your thumb, begin the gusset.
Row 1: Knit until 2 stitches before the midpoint on your mitten. Place a stitch marker. Knit 4 stitches after the marker and place another marker. Knit until the end of the round.
Row 2: Knit until the first stitch marker and pass it to the other needle. Knit 1, M1R (make 1 right), knit until the last stitch before the second stitch marker, M1L (make 1 left), knit 1. Pass the stitch marker, then knit until the end of the round.
Row 3: Knit.
Repeat row 2-3 until the thumb gusset is big enough to close around your thumb. End on a knit row.
Step 5: Step 5: Knitting the Rest of the Hand
Knit until the first stitch marker for the thumb. Remove the stitch marker and put the thumb stitches onto a placeholder. Do not knit the thumb stitches. Knit the rest of the round.
Continue knitting all rounds until the mitten reaches the top of your pinky.
Step 6: Step 6: Top Decreases
Decrease as follows:
Round 1: *knit 6, knit 2 together* until the round finishes
Round 2: knit
Round 3: *knit 5, knit 2 together* until the round finishes
Round 4: knit
round 5: *knit 4, knit 2 together* until the round finishes
round 6: knit
round 7: *knit 3, knit 2 together* until the round finishes
round 8: knit
round 9: *knit 2, knit 2 together* until the round finishes
round 10: *knit 1, knit 2 together* until the round finishes
round 11: *knit 2 together* until the round finishes
Break yarn, leaving an end of 8-12 inches. Thread onto a tapestry needle. Working from right to left, transfer the remaining stitches onto the tapestry needle and pull yarn through.
Step 7: Step 7: the Thumb
Pick up the thumb stitches that are on the placeholder. Knit all the rounds until the mitten is 1/4 inch shorter than desired
*Knit 2 together* to the end of the round
Break yarn, leaving a tail of 5-6 inches. Thread onto a tapestry needle. Working from right to left, transfer the remaining stitches onto the tapestry needle and pull yarn through.
Step 8: Step 8: Finishing
Sew in all of the yarn ends. Close and tie up the hole in between the thumb and the rest of the mitten.
Step 9: Step 9: the Second Mitten
Repeat the instructions for a second mitten.
