Introduction: Cute Clay Jewellery DIY
About: Dreamer, Mother of 2, Handmade jewellery designer working with terracotta, resin and polymer clay
In this instructable we shall learn how to make clay jewellery, specifically terracotta clay earrings. I will be making a heart shaped earring with a little birdie dangler.
It may seem very intricate and complicated. Trust me. By the end of this tutorial, you will feel its very much do-able!
So what are we waiting for? Let's learn how to make this cute pair of earrings
Step 1: Items Needed to Make a Heart Stud
1. A small ball of clay
2. A rolling pin
3. Heart shape plunger cutter
Step 2: Roll Out the Clay to a Thickness of About ¾th of a Cm
Step 3: Cut Out a Heart Using the Plunger Cutter
Step 4: Press the Edges of the Heart to Give a Smooth Contour
Step 5: You Should Be Having Something Like This
Step 6: Items Required to Make a Little Bird
1. A ball of clay
2. A toothpick
Step 7: Pinch One Side of the Clay Ball to Get a Tapered Portion.
This will become the tail of the bird
Step 8: Pinch Another Side to Create a Smooth Right Angle Triangle With a Gentle Curvature
This shall be the head of the bird
Step 9: At the Head Portion, Make Another Pinch to Create the Beak
Step 10: Use the Toothpick to Make an Impression for the Bird's Eye on Both the Sides
Step 11: Make a Short Linear Impression on the Beak, With the Toothpick Held Parallel to It
Step 12: With the Toothpick Held Parallel to the Tail, Make a Few Linear Impressions on the Tail
Step 13: Your Bird Should Now Look Like This
Step 14: Using the Toothpick, Gently Draw the Shape of the Wings Onto Either Sides of the Body
Step 15: Gently Scrape Off And/or Press the Surface Adjoining the Outline Drawn
This helps to give an elevated dimension to the wings
Step 16: The Bird Should Now Look Something Like This
Step 17: Use a Couple of Eye-pins to Help Connect the Heart and Bird
Step 18: Insert the Eye-pins in Open Position As Shown.
Step 19: Let It Dry Completely and Then Fire the Clay Pieces
You can use a kiln to fire the pieces.
If you plan on creating clay pieces on a regular basis and wish to try out glazes, The FireBox 8x6 LT Multimedia Kiln by Skutt is a great starter kiln. And guess what Instructables is hosting a clay contest in which the grand prize winner gets this amazing kiln along with loads of clay suppplies, glazes, Laguna clay and tools from The Ceramic shop
Or even fire them at home WITHOUT a kiln. You can find a separate instructable that i created to Fire natural clay WITHOUT A KILN
All my clay jewellery and keepsakes are fired using this method and painted with acrylic paints. Feel free to take a peek into my facebook page Festoons Creations
You can buy my creations from Festoons Etsy shop
Step 20: Paint Them With Colours of Your Choice
Using acrylic colors, paint them with colors of your choice. Once the paint coat dries completely, you can coat it with a layer of varnish for an extra shine and protection
I have used Camlin acrylic colors and Fevicryl acrylic colors, available here in India. But you can use any brand of acrylic colors to paint them.
Step 21: Connect Them and Close the Loop of the Eye Pin to Create a Lovely Dangling Earring
Step 22: Glue on the Stud Base to the Back of the Heart
Using araldite or e600 or any epoxy jewelry glue, glue on the stud base to the back of the heart and let it dry overnight. Your cute lovely clay jewellery - heart and bird earrings is ready
Step 23: If You Found Instructable Helpful, I Greatly Appreciate Your Vote in the Contest
I have entered this instructable in the Clay contest hosted by Instructables.
If you found this instructable helpful, i highly appreciate your support with a vote.
Thank you all for reading
If you try this out, do post your creations in the comments. Looking forward to see all your wonderful creations
