Introduction: Cute Wooden Train
Build your own wooden train even if you have no experience at woodworking.
- Train (the model was made on a laser cutting machine using MDF 3 mm (0.12in);
- Super glue;
- Brush;
- Craft paint for MDF (I used a dark brown paint).
Step 1:
This project was documented on the video above. The article and video complement each other. I hope you enjoy it.
Step 2: Designing
As the title and subtitle suggests, it's a project about a wooden train. I created it in a way that anyone can build. In this article, there're two files. The train-3D-model.f3d file is a 3D model created on Fusion 360, as you can see on the image above. This model was important to determine the train measurements and how the pieces would fit with one another.
The train-2D-drawings.dxf file contains all the drawings that generated the 3D model (see the screenshot above). I sent this file to a laser cutting company. In this case, I ordered them to cut everything on MDF 3mm (0.12in).
You can see the length of any piece by opening this file and selecting the desired line with the dimension tool. If you are using Fusion 360, just type D and select the line.
Step 3: Assembling
I glued the wooden pieces with super glue and, when I finished assembling the train, I painted it with a dark brown craft paint. In the end, I applied a coat of varnish.
Step 4: Measures
The train measures are:
- Height: 113mm (4.45in)
- Length: 304mm (11.97in)
- Width: 86mm (3.39in)
Step 5: Other Resources
This article and files are available on GitHub.
