Introduction: Cutting Avocado Model
Using, assembling, and printing the avocado model.
Step 1: Placing the Model
Set the model onto the edge of the table top.
Step 2: Adjusting the Model
Insert the screw at the bottom of the model and tighten it until it is firmly clamped onto the table.
Step 3: Placing Avocado
Place the avocado in the tray in between in the two prongs.
Step 4: Cutting the Avocado
Cut the avocado using a knife in between the two prongs.
Step 5: Flipping and Placing Avocado
Take the avocado out of the tray and flip it around to the uncut side. Then put the avocado back inside the tray.
Step 6: Cutting Whole Avocado
Use the knife to cut the rest of the avocado in half. Take out the two pieces of avocado.
Step 7: Assembling Instructions
The model comes in two pieces, the main device to clamp onto the table and a screw. Insert the screw at the bottom of the model and twist to tighten and clamp the main device onto the table.
Step 8: Printing Instructions
Open the STL file in a 3D printing software. Rotate the model so the clamp bar is not touching the baseplate. The software should automatically connect to a 3D printer if the file opens. You can then click print and wait for the model to print.
