Introduction: Cutting Board in School
making a cutting bored step by step
Step 1: Safety
safety is number one priority on the work site
Step 2: Tools and Gear Needed
the kit you will need to build a cutting board is a chop saw, a
table saw, a belt sander, a hand sander, a router and a C and C machine and plainer and glue and clamps.
Step 3: Find Wood
find a wood material that is the desired and semi flat
Step 4: Cut Wood
cut wood into desired lengths i cut the wood into 12 inch pieces and then i cut them into 1.5 inch strips
Step 5: Gluing
to glue the strips together you need to turn them on the side lather them in lots of glue flip back to original position and then push together and then clamp the wood nice and tight
Step 6: Sanding
so after the bored is glued its all bumpy with glue so you need to plan the bored in the planner and then use the cNc machine to machine down the bored smooth
Step 7: Route
use the router to make the edges of the bored round
Step 8: Finish Sand
use really fine grit sand paper and make it supper smooth
Step 9: Laser Engrave
use a cNc laser engraver to engrave an image if wanted
Step 10: Oil
use mint oil and rub lots of oil all over it and do multiple layers
