Cutting Foam
Intro: Cutting Foam
This Instructable is part of a collection of I'bles on how to make foam weapons. Check it out here!
STEP 1: Craft Foam
If you're cutting thin craft foam, plain old scissors work pretty well for this job, but if you're a perfectionist, this method gets you slightly cleaner cuts.
If you're cutting thick foam (say, a 1/4" sheet,) never use scissors if you can avoid it. They really make a mess.
If you're cutting a fancy or curved design, it's best to use scissors for the thin foam and a pocket knife or jackknife for the thick stuff. It's tricky, but you'll get the hang of it.
Tools:
Tools:
- Ruler
- Kitchen knife (if possible)
- Pocket knife or jackknife
- Pencil (optional)
- Cutting surface
STEP 2: Carving Sharp Edges
This method of carving a blade takes a lot of practice. Even for me, the cut comes out a jagged mess most of the time. Also, the electric kitchen knife shakes the hell out of everything. Be prepared.
Materials
Materials
- Foam blade
- Electric kitchen knife
- Pencil
2 Comments
nbrown-1 9 years ago
You can use a dremel tool to get a smoother final finish to the weapon. Makes it look much nicer.
Fine sandpaper also helps with that.
Sadi789 9 years ago
