Introduction: Cutting Safety, Box Knife, Xacto, Guides and Tips
The object of this instructable is to, while creating or doing projects, is to think about safety while using tools.
I have singled out cutting , because I am currently slicing a lot of vinyl in projects and thought it would be an opportune time
to show some safety tips and and inexpensive cutter guides for blades, that can be made on the cheap . If you've price a cutter guide .you might be shocked at the cost. I was.
Step 1:
I'm a firm believer in the re-use/recycle of stuff. with a little thought scrap items and junk just laying around can be turned into useful
tools
Items I put together:
1. mini-din rail- 50 cents from a scrap enclosure
2. threshold for carpet- neighbors trash
3. drawer/door handles- stripped from old cabinets over the years
Step 2:
Mark hole location for mounting and drill holes
Step 3:
There are many way to fasten handle to guide,
bolt and nuts
screws
pop rivets
I welded a handle to a 1 inch x 48 inch piece of angle iron to cut drywall
Step 4:
Something to think about when cutting:
Sharp cutters work better
Hand protection is a must
Cut away from your body/ or at least make sure body parts are NOT in line of the cut
Anticipate what might happen if blade slips
Hold both guide and blade with a relaxed but firm grip.
The Teacher Contest
10 years ago on Introduction
Thank you, just grabbed the leather gloves for effect, There are many better choices for gloves as you mentioned. I have a pair of "kevlar" knit gloves that work really well, While we're on the subject, It's important to pick the right glove for the task but also pick something you like, with the correct fit. Their is always an excuse not to put on gloves( I am guilty of this too!!). If you stick something in your hand or slice a finger, excuses are foolish. Once again thanks for the complement
