Introduction: D Flip-Flop, MiniPCB, 10A-20, Rev A1-01
About: I'm Nolan, a circuit design engineer and creator of miniPCBs—small, standardized circuit boards for learning real-world electronics. I design miniPCBs for students, teachers, and hobbyists who want hands-on pr…
Step 1: Collect Components
The PCB is a two layer board, and designed to be easy to manufacture and assemble. And it is optimized for cost by being panelized on 100 x 100 mm squares.
Signals are routed on the bottom layer (the layer with the part number), and a common ground plane (as uncut as possible) is on the top layer.
The P1 connector is located in a standard position with respect to the board edges: making it possible to build a universal tester, backplane, or stand.
Step 2: Solder Components
For ease, start with the shortest components.
Step 3: Test With Digilent's Analog Discovery 2/3
I used ChatGPT to generate a test script. It runs successfully from VS Code. I removed each signal (separately) and the script failed as expected, so this pass is convincing to me. It just doesn't look cool. Watching test points on a scope while running the script would be way cooler!
#!/usr/bin/env python3
10A-20.py — AD3 D Flip-Flop miniPCB functional test (hard-coded)
WIRING (fixed):
DIO4 -> D
DIO5 -> CLK
DIO6 <- Q
DIO7 <- /Q
AD3 V+ -> board VCC (script sets V+ = +5.0V)
AD3 GND -> board GND
What you should see:
- Terminal prints Python path, device found, power enabled, then PASS/FAIL.
- Writes a JSON log file: dff_test_log.json
from __future__ import annotations
import json
import random
import sys
import time
from dataclasses import dataclass, asdict
from typing import Optional, Tuple, List, Dict, Any
# HARD-CODED TEST CONFIG
PIN_D = 4
PIN_CLK = 5
PIN_Q = 6
PIN_NQ = 7
ENABLE_VPLUS = True
VPLUS_VOLTS = 5.0
ACTIVE_EDGE = "rising" # "rising" or "falling"
SETUP_MS = 5.0
PULSE_MS = 2.0
PROP_MS = 2.0
HOLDCHECK_MS = 5.0
RANDOM_CYCLES = 16
RNG_SEED = 1
LOG_JSON = "dff_test_log.json"
VERBOSE = True
@dataclass
class Sample:
t_s: float
d: int
clk: int
q: Optional[int]
nq: Optional[int]
@dataclass
class Failure:
step: str
d: int
clk: int
q: Optional[int]
nq: Optional[int]
expected_q: Optional[int]
expected_nq: Optional[int]
note: str
def _b2i(x: bool) -> int:
return 1 if x else 0
def main() -> int:
print("=== AD3 DFF TEST (hard-coded) ===")
print(f"Python: {sys.executable}")
print(f"Version: {sys.version.split()[0]}")
print("")
try:
import dwfpy as dwf
except ModuleNotFoundError:
print("ERROR: dwfpy is not installed in THIS interpreter environment.")
print("Install it into the interpreter shown above with:\n")
print(f' "{sys.executable}" -m pip install --upgrade pip')
print(f' "{sys.executable}" -m pip install dwfpy\n')
print("If you're in VS Code: Select Interpreter -> your .venv python, then reinstall.")
return 2
random.seed(RNG_SEED)
setup_s = SETUP_MS / 1000.0
pulse_s = PULSE_MS / 1000.0
prop_s = PROP_MS / 1000.0
holdcheck_s = HOLDCHECK_MS / 1000.0
samples: List[Sample] = []
failures: List[Failure] = []
def log_sample(dv: int, clkv: int, qv: Optional[int], nqv: Optional[int]) -> None:
samples.append(Sample(t_s=time.time(), d=dv, clk=clkv, q=qv, nq=nqv))
def fail(step: str, dv: int, clkv: int, qv: Optional[int], nqv: Optional[int],
exp_q: Optional[int], exp_nq: Optional[int], note: str) -> None:
failures.append(Failure(step, dv, clkv, qv, nqv, exp_q, exp_nq, note))
if VERBOSE:
print(f"[FAIL] {step}: D={dv} CLK={clkv} Q={qv} /Q={nqv} expected Q={exp_q} /Q={exp_nq} :: {note}")
# Try opening the first available WaveForms device
try:
with dwf.Device() as device:
print(f"Found device: {getattr(device, 'name', 'Unknown')} ({getattr(device, 'serial_number', 'Unknown')})")
# ---------- Power Supplies (V+) ----------
# Uses dwfpy AnalogIO generic channel/node access:
# channel 0 is typically V+, node 1 voltage, node 0 enable; then master_enable.
def enable_vplus(volts: float) -> None:
device.analog_io[0][1].value = float(volts) # voltage node
device.analog_io[0][0].value = True # enable node
device.analog_io.master_enable = True # master enable
def disable_vplus() -> None:
try:
device.analog_io[0][0].value = False
device.analog_io.master_enable = False
except Exception:
pass
if ENABLE_VPLUS:
try:
print(f"Enabling V+ = {VPLUS_VOLTS:.3f} V ...")
enable_vplus(VPLUS_VOLTS)
time.sleep(0.15)
except Exception as e:
print("WARNING: Could not enable V+ from Python.")
print(" You can still run the digital test if the board is powered externally.")
print(f" Details: {e}")
print("")
# ---------- Digital IO ----------
io = device.digital_io
# Drive D and CLK
io[PIN_D].setup(enabled=True, state=False)
io[PIN_CLK].setup(enabled=True, state=False)
# Read Q and /Q
io[PIN_Q].setup(enabled=False)
io[PIN_NQ].setup(enabled=False, configure=True)
driven_d = 0
driven_clk = 0
def set_d(v: int) -> None:
nonlocal driven_d
driven_d = 1 if v else 0
io[PIN_D].output_state = bool(driven_d)
def set_clk(v: int) -> None:
nonlocal driven_clk
driven_clk = 1 if v else 0
io[PIN_CLK].output_state = bool(driven_clk)
def read_q_nq() -> Tuple[Optional[int], Optional[int]]:
try:
io.read_status()
return _b2i(io[PIN_Q].input_state), _b2i(io[PIN_NQ].input_state)
except Exception:
return None, None
def expect(step: str, exp_q: Optional[int], exp_nq: Optional[int], note: str = "") -> None:
qv, nqv = read_q_nq()
log_sample(driven_d, driven_clk, qv, nqv)
ok = True
if exp_q is not None and qv != exp_q:
ok = False
if exp_nq is not None and nqv != exp_nq:
ok = False
if qv is not None and nqv is not None and qv == nqv:
ok = False
note = (note + " | " if note else "") + "Sanity: Q and /Q are identical (should be complements)."
if not ok:
fail(step, driven_d, driven_clk, qv, nqv, exp_q, exp_nq, note)
elif VERBOSE:
print(f"[ OK ] {step}: D={driven_d} CLK={driven_clk} Q={qv} /Q={nqv}")
def pulse_active_edge() -> None:
if ACTIVE_EDGE == "rising":
set_clk(0)
time.sleep(0.001)
set_clk(1) # active edge
time.sleep(pulse_s)
set_clk(0)
else:
set_clk(1)
time.sleep(0.001)
set_clk(0) # active edge
time.sleep(pulse_s)
set_clk(1)
# ---------- Quick smoke read ----------
set_clk(0 if ACTIVE_EDGE == "rising" else 1)
set_d(0)
q0, nq0 = read_q_nq()
print(f"Initial read: Q={q0} /Q={nq0}")
print("Starting functional test...\n")
# ---------- Prime ----------
set_d(0)
time.sleep(setup_s)
pulse_active_edge()
time.sleep(prop_s)
expect("prime_to_0", 0, 1, "Priming with D=0")
set_d(1)
time.sleep(setup_s)
pulse_active_edge()
time.sleep(prop_s)
expect("prime_to_1", 1, 0, "Priming with D=1")
# ---------- Pattern ----------
pattern = [0, 1, 0, 1, 1, 0, 0, 1]
for i, dv in enumerate(pattern):
q_before, nq_before = read_q_nq()
log_sample(driven_d, driven_clk, q_before, nq_before)
set_d(dv)
time.sleep(setup_s)
q_hold, nq_hold = read_q_nq()
log_sample(driven_d, driven_clk, q_hold, nq_hold)
if q_before is not None and q_hold is not None and q_before != q_hold:
fail(f"hold_no_clock_change_{i}", driven_d, driven_clk, q_hold, nq_hold,
q_before, (1 - q_before) if q_before in (0, 1) else None,
"Q changed after D changed without a clock edge.")
pulse_active_edge()
time.sleep(prop_s)
expect(f"pattern_clock_{i}", dv, 1 - dv, "Latch check")
set_d(1 - dv)
time.sleep(holdcheck_s)
expect(f"post_edge_hold_{i}", dv, 1 - dv, "Hold check")
# ---------- Random ----------
for i in range(RANDOM_CYCLES):
dv = random.randint(0, 1)
set_d(dv)
time.sleep(setup_s)
pulse_active_edge()
time.sleep(prop_s)
expect(f"random_clock_{i}", dv, 1 - dv, "Random latch check")
passed = (len(failures) == 0)
report: Dict[str, Any] = {
"passed": passed,
"device": {"name": getattr(device, "name", None), "serial_number": getattr(device, "serial_number", None)},
"config": {
"pins": {"D": PIN_D, "CLK": PIN_CLK, "Q": PIN_Q, "nQ": PIN_NQ},
"vplus_volts": VPLUS_VOLTS if ENABLE_VPLUS else None,
"edge": ACTIVE_EDGE,
"setup_ms": SETUP_MS,
"pulse_ms": PULSE_MS,
"prop_ms": PROP_MS,
"holdcheck_ms": HOLDCHECK_MS,
"random_cycles": RANDOM_CYCLES,
"seed": RNG_SEED,
"failures": [asdict(f) for f in failures],
"samples": [asdict(s) for s in samples],
with open(LOG_JSON, "w", encoding="utf-8") as f:
json.dump(report, f, indent=2)
print("\n========== D FLIP-FLOP TEST RESULT ==========")
print("PASS ✅" if passed else "FAIL ❌")
print(f"Failures: {len(failures)}")
print(f"Log written to: {LOG_JSON}")
if ENABLE_VPLUS:
print("Disabling V+ ...")
disable_vplus()
return 0 if passed else 1
print("ERROR: Could not open/use the WaveForms device from Python.")
print("Common causes:")
print(" - WaveForms is open (device busy) -> close WaveForms and retry")
print(" - WaveForms runtime/SDK not installed correctly")
print(" - USB permissions / cable / hub issues")
print("")
print(f"Details: {e}")
return 3
if __name__ == "__main__":
raise SystemExit(main())
