Introduction: D4E1 - Box for Project 'motivational Rehabilitation'
This Instructable is an optional box for the elements of the project that can be found here.
It uses standard buyeable elements and laser cutting technique.
- IKEA SAMLA box 22 l https://www.ikea.com/nl/en/p/samla-box-with-lid-transparent-s69440822/
- IKEA SAMLA insert for box 11/22 l https://www.ikea.com/nl/en/p/samla-insert-for-box-11-22-l-transparent-50102973/
- ABS plastic with a thickness of 3 mm
- non-slip feet to lock separations into place (optional)
Step 1: Laser Cutting the Partitions
Cut the files below out of the ABS-material.
make sure colors and line thickness are correct for the laser cutter you use.
Step 2: Combining the Elements
Place the partitions in the slots made for them in the long part, then place the combination on the bottom of the box.
If desired, secure partitions into place with raised anti-slip stickers.
Place the insert on top and close the box, now you have your storage/carrying case!
Step 3: Enjoy the Process
Have fun making!
