Introduction: DAMAC 19" Mountable Data Rack
This Wall Mountable Data Cabinet is specially designed for high
traffic environments, such as in schools, warehouses, or in places with limited available space. It has smooth, rounded edges to prevent injuries and liabilities, front and rear swing-out features, lockable front and rear sub-panel, and dust and noise reduction features. It also has vented panels on the top and bottom. The Heavy Duty Wall Mount Server Rack is designed for applications requiring larger load capacities, up to 300 lbs. This enhanced safety feature is ideal for schools and retail locations where exposed sharp corners are a liability.
STANDARD WALL MOUNT WALL MOUNT RACK
24”/12U, 36”/18U, 48”/26U PREMIUM DATACENTER PRODUCTS
The Standard Wall Mount Rack is an ideal solution for wallmounted applications in high-traffic areas. The corners and edges are fully radius welded, providing optimal safety in schools and retail locations where exposed sharp corners are a liability.
The enclosure holds up to 125 pounds and features swingout capabilities for front and rear equipment access. Cable knockouts in the top and bottom provide flexibility for specific cable and conduit configurations. The rear sub-panel is lockable. Solid side panels minimize internal dust collection and reduce the noise produced by the equipment housed within. The vented top and bottom panels promote proper cooling and accept fan kits and filters. The locking rack door is removable and reversible and is available in a Plexiglas or solid configuration.
APPLICATION
• High Traffic Areas
• Retail/Schools
• Space Limited Areas
• Warehouse
• Security Systems
SPECIFICATIONS
• Fully Welded Construction: 125 lbs. weight capacity
• 19” rackable per EIA-310-D Standard
• (2) sets of adjustable mounting rails
• Right or left hinge locations available, (Right-side standard)
• Locking door and rear compartments, keyed alike
• NEMA and custom configurations are available
• UL Listed
MODEL SIZES
• Height: 24”/12U, 36”/18U, 48”/26U
• Width: 23.25” • Depth: 24”
• Rails: 10-32 Tapped
Pre-Configured Models:
Safety Edge Wall Mount Rack, 19" EIA 10-32 Tapped Rails
WLR24AKP1VVV-3: H x W x D 24 x 23.25 x 24
Plexi Glass Door, Vent Sides, Vent Top and Bottom, Knock Outs for Cable Entry
Door: Plexi
Vented: Sides, Top, and Bottom
Color: Black
WLR36AKP1VVV-3: H x W x D 36 x 23.25 x 24
Door: Plexi
Color: Black
WLR48AKP1VVV-3: H x W x D 48 x 22 x 24
Door: Plexi
Color: Black
Features Include:
12U, 18U, or 26U Available
50lbs, 60lbs, 70lbs, Weight
Removable and Reversible front door Locking door Plexi Glass front door Safe, round edges Open rear, ideal for accessibility to wall Top and bottom cable knockouts, 2 at 3.0'', 2 at 0.88'' Available in 12u (24 X 23.2 X 24), 18u (36 X 23.2 X 24), and 26u (48 X 23.2 X 24) Offered in black Lances for internal cable management Vented side panels and top panel EIA-310-D Standard Universal hole spacing
