Introduction: DC Motor Mount
I made this motor mount for my friends project
here is her blog link: https://wp.nyu.edu/rc3989/2018/12/12/caged/
Step 1: Measure Dimensions
Use a caliper to measure dimensions.
If you can find access the data sheet, the dimensions will be listed there as well.
but i found this motor a while back, so i couldnt find it
Step 2: Design on Fusion 360
I design the model on Autodesk Fusion 360, starting from the fitting part, then adding the support and mounting structure. I designed the mounting hole to fit M3 screws. i also designed the support because it snap of easier than generated support, also the bottom side will look better
Step 3: Pre-printing: Slicer
Use any slicer that works for your printer
in my case, I'm using a ultimaker printer, so I use cura to prepare the print file.
I designed the support for the vertical mount, so no need to select support.
Step 4: Print! Files Available on Thingiverse
The support comes right off with little effort.
Gumroad page:
Thingiverse page:
