Introduction: DC Power Pack
Step 1: Supplies
Gather your supplies. You will need the following.
NOCO HM318KS battery box I purchased from Walmart. https://www.walmart.com/ip/NOCO-Snap-Top-HM318BK-...
Car DC 12V power socket 3 hole panel this comes with 2 usb sockets, cigarette socket and a digital voltmeter. Amazon https://www.amazon.com/Depvko-Cigarette-Splitter-Waterproof-Voltmeter/dp/B08SHBBT8C/ref=gp_aw_ybh_a_1?_encoding=UTF8&psc=1&refRID=S202GYFW9ZYJ75MKDFV1
UB12350 sealed lead acid battery 35AH Walmart https://www.walmart.com/ip/New-12V-35Ah-AGM-Sealed-Lead-Acid-Battery-UB12350-Group-U1-Free-Shipping/168009742
1 1/8 drill bit
Inline fuse holder and 7.5 amp fuse. any fuse holder will do. I had one already
Wire connectors
Battery tender or any trickle charger
Toggle switch I wired the usb and volt meter through the switch so they would not be a constant drain on the battery.
I purchased a Sunjack camp light 340 lumens to use with my power pack, but it is not needed.
Update 10-20-2017
I got the chance to use it due to an extended power outage. I powered my light and charged two phones over the course of about 18 hours. When I started using it it had 12.7 volts. When I finished using it it was still at 12.3 volts. That equates to about 30% of the charge used.
Step 2: Drilling the Holes
Step 3: Installing the Panel and Switch
Step 4: Wiring
For power wires I ran the one for the cigarette socket straight to the battery. The ones for the USB socket (because it has a light on it) and the voltmeter I ran through the toggle switch so it would not drain the battery. From the toggle switch to the USB socket and the voltmeter I put in an inline fuse holder with a 7.5 amp fuse.
I also attacked a SAE ring adapter to the battery so I could charge it without having to take the top off.
