Introduction: DC7600 Media PC Upgrade
The DC7600 is a perfect size for a media PC. It's about the size of an older DVD player (VCR). I love the fact it has so many USB slots and easy-access audio ports. The power supply is only 250w, so that'll have to be replaced. The box I got also only had 1gb of Ram, which is also something to upgrade. Because we'll want to hook it up through HDMI, we'll need a new video card (another reason for the power supply upgrade). Also, while the 80gb drive is good enough to install an OS and stream media, we'll upgrade it by installing two 500gb drives.
I used the following tools:
1 Flathead Screwdriver
1 Phillips Screwdriver
1 Pair of Metal Snips
1 Single-hand Hack Saw
1 Hot-glue Gun
And I bought the following supplies:
1 DC7600 HP Slim PC
2 WD 500gb SATA Harddrives
1 SATA Cable
4 Crucial 240 Pin 1GB DDR2 Ram Chips CT12864AA667
1 GeForce G100 512Mb DDR2 DVI/HDMI Video Card Low Profile
1 20 to 24 Pin M/F ATX Power Converter Adapter Cable
1 Chiefmax MicroATX 450 PSM-CM-450W-24PIN Power Supply
I already had the drives, so this project cost me about $200.
1 Hot-glue Gun
1 DC7600 HP Slim PC
1 SATA Cable
Step 1: Remove Case Cover and Power Supply
Unscrew a screw located on the back and press the two tabs on the sides (clearly marked) to slide off the case cover. The power supply swivels and pops out of the case easily. Unhook all the power cables for now.
Step 2: Slide Up CD Drive Bay to Access HD
The CD drive bay slides up, giving you access to the SATA drive beneath it. We'll need to remove the drive (after unhooking the power and SATA cable first). The green piece on the side is a lever that you need to pull toward the CPU and then slide the drive toward the CD drive bay. It snaps out easily. I removed the cables going to the CD drive for now also.
Step 3: HD Comparison
This was a good drive back in the past, but nowadays we need lots more storage. In this case, I had two 500gb drives (1TB) handy so that's what I'm using.
Step 4: Place New HDs
One HD goes where the original 80gb drive was and the other slides underneath the CD drive. You can go ahead and hook up the cables back to all three drives. This is where you'll need an extra SATA cable.
Step 5: Disassemble Old Power Supply
Disassemble the old power supply. We'll need the casing to hold the new power supply. Remove all screws and pull out the board, fan, and heatsink (basically the guts). Remove the paper as well.
Step 6: Place New Power Supply in Old Enclosure
The new drive will just slide in the old case. You'll need to trim away some metal, so get the metal snips handy. There's just enough room for the cables to go around the old casing. To avoid anything from sliding, take the hot-glue gun and lock down the supply along adjoined surfaces.
Step 7: Remove Case Metal to Fit New Power Supply
Remove the the serial port (with the |0|0| label) by unplugging it from the motherboard and unscrewing the connector from the case frame. Take the hack saw and the metal snips and take down the metal to beneath where the serial started vertically. Be sure to blow out any metal filings and be careful not to cut yourself on the edges.
Step 8: Check Power Supply Fit
Once done, take the new power supply in the old frame and make sure it fits to where the top is level (so that the case cover will go back on correctly).
Step 9: Hook Up Power Cables
Hook up the power supply cables to the drives and the board. This is where you need the adapter, as the DC7600 motherboard has a mini-ATX plug and the 450w ATX power supply is too large.
Step 10: Install RAM
Make sure the ram is seated and tie back the cables to maximize the air flow.
Step 11: Install Video Card
Now you just need to add the video card. This card is low profile, so it fits the case. You'll have to remove the metal insert on the back of the case by first swiveling up the metal piece holding them all in. Then you just slide the card in to the PCI-E slot.
Step 12: Replace Cover
Once the video card is in and well-seated, set the metal piece holding the tab down and replace the PC cover. You're done.
