Introduction: DF Player Mini Play Audio File
Hello friends, today in this Project, I show you how to Play audio file by using Arduino and Df player. The DFPlayer Mini is a small and low cost MP3 module player with an simplified output directly to the speaker. The module can be used as a stand alone module with attached battery, speaker and push buttons or used in combination with an Arduino UNO or any other with RX/TX capabilities. For making this, I am using:-
1- Arduino UNO https://amzn.to/3vXP8Ht
2- Df Player Mini https://amzn.to/3En5vQY
3- Speaker https://amzn.to/3En5vQY
4- Jumper wires https://amzn.to/3En5vQY
5- Bread Board https://amzn.to/3En5vQY
Step 1: Connect Speaker
First of all connect 3 watt speaker to DF mini Player.
Step 2: Connect DF Player Mini to Arduino
Connect DF player Mini to arduino
Step 3: Copy Mp3 File to SD Card
Step 4: Insert SD Card Into DF Player Mini
Step 5: Code Write to the Arduino
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Use pins 2 and 3 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 2; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 3; // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the Player object
DFRobotDFPlayerMini player;
void setup() {
// Init USB serial port for debugging
Serial.begin(9600); // Init serial port for DFPlayer Mini
softwareSerial.begin(9600);// Start communication with DFPlayer Mini
if (player.begin(softwareSerial)) {
Serial.println("OK");
// Set volume to maximum (0 to 30).
player.volume(30);
// Play the first MP3 file on the SD card
player.play(1);
else {
Serial.println("Connecting to DFPlayer Mini failed!"); } }
void loop() { }
Step 6: Lets Test
You can Purchase from:-
3- Speaker https://amzn.to/2ZDQ207
4- Jumper wires https://amzn.to/2ZDQ207
5- Bread Board https://amzn.to/2ZDQ207
