Introduction: DIN Rail Mount for Raspberry Pi 4
Sometimes it is useful to mount your Raspberry Pi 4 based project permanently in a control cabinet - for example in home automation or industrial applications. In such cases our RasPiBox Enclosure Set for Raspberry Pi A+, 3B+ and 4B can help you to come to a rugged solution with professional look. In this documentation we will show you how to use RasPiBox with the different Raspberry Pi Boards boards
Step 1: Tools and Materials
Materials
- Raspberry Pi 4B
- RasPiBox Open 2.x for Pi4
- thin solder wire
Tools
- Soldering iron
- screw driver
- side cutting pliers
- needle nose pliers
Step 2: PCB Assembly
The enclosure kit includes a prototyping pcb with integrated 5V power supply. So you can use for example 24V DC by the cabinet to power the Raspberry Pi inside the enclosure.
In the first step you have to assemble this PCB of the RasPiBox kit. Please follow the attached construction manual.
If needed, you can add additional circuit or modules (RTC, communication...) on the breadboard area beside the Raspberry Pi. Beside the breadboard area you will find all marked GPIO and power pins.
Step 3: PCB Mounting
Step 4: Place the Raspberry Pi
now you can plug the Raspberry Pi 4 to the main pcb
Step 5: Open the Terminal Covers
Depending on the used terminals you have to remove the terminal covers of the top shell. These covers comes with rated break points. You can remove it with a screw driver and a nose pliers
Step 6: Cabinet Mount
After mounting the top shell you be ready to mount the RasPiBox in a cabinet.
