Introduction: DISPENSADOR DE GEL
Welcome to my new project, it is the first time that I use the application but as you draw you get used to it, today I will present you how to make a gel dispenser, and next week I will present you a custom design
Step 1: CARA 1
The first procedure we have to do is give the line to be able to draw, in the next step I will tell you what are the measures that we are going to use
Step 2: CARA 1
To start drawing you have to start at point 0 of the x axis, as you already have the means you proceed to draw with the lines, follow the model to avoid mistakes
Step 3: Cara 1-estilos,colores
Here you will wonder how I put that color style, you calm, when we finish drawing all the edges of the face 1 we will proceed to right-click on the face you will get several options in which you look for appearance and you go to plastic and choose the one you like the most
Step 4: CARA 2
We do the same as with face 1, only now they are other measurements, to make the circles in the middle of the face, press where it says center diameter circle and give it a dimension of 3 and hit enter to see it in 3D, next upper right there is a cube, where it says front on the right side there is a small square you click and you can see it 3D
Step 5: CARA 2 (COLORES)
The same we did in face 1, we will put the same color and appearance so that everything is even and looks neat, right click on the drawing and you go to appearance and choose the same style
Step 6: CARA 3
Here I present you face 3, we repeat the steps of face 1 and face 2, it is actually very simple you repeat the previous steps, you have to be very careful not to make a mistake because after finishing the 3 faces we put them all together so that we can form the shape and figure
Step 7: CARA 3
Here you can see that it is the last face that we make, the fourth face is the same as that of face 1, we put color and the last step would be to assemble that I will explain it to you in the next indications
Step 8: ENSAMBLAJE
Here is the last step, it is to put all the faces together and give it shape, I hope you liked it a lot, do not forget to recommend me and very cool things will be sold
Step 9: CARA D
As you already have a little more experience with the other faces, you follow the same procedure for this one but changing the measurements, there is no margin for error but it will be wasted time
Step 10: ENSAMBLAJE CON LA CARA D
now we only add the D side to the instructable, note that when you assemble it you do it well to avoid errors
Step 11: DISEÑO PERSONALIZADO
For this choose an image from the internet and start cutting it, there as you can see I show you the option to cut it with the points, take your time to do it calmly this is done because then you will put it on one side of your design
Step 12: IMPORTANDO DOCUMENTO-PONIENDO VALORES-SIMULACIÓN DENTRO DE LA IMPRESORA 3D
the application you will download is: RDWorksV8 so you can cut the image
Step 13: Paso Final
As we already have the cropped image, now you add it to the instructable and basically it has to be like that. I hope you liked it, don't forget to like it and subscribe until next time.
