Introduction: DIY 20,000mAh Homemade Powerbank – 3D Printed Edition
Welcome to this DIY project where you’ll build a powerful 20,000mAh power bank using minimal materials, a 3D printer, and basic electronics skills. In this instructable, you’ll learn how to combine printed parts, an IP5328P charging module, 4×18650 cells, and a custom battery holder (made from aluminum and wire) to create a fully functional and attractive portable charger. Follow along through my step-by-step guide with clear images for each process!
Materials:
  1. PLA Filament: For 3D printed parts
  2. Printed Parts: Printables (link here)
  3. IP5328P Module: Charging and power management
  4. M3 Screws (x4): For mounting the module
  5. M4 Screws (x2): For mounting the case
  6. 18650 Cells (x4): Lithium-ion batteries
  7. Aluminum Strip: For constructing the battery holder
  8. Aluminum Wire (or equivalent): To wrap the battery holder for mechanical pressure and conductivity
Tools:
  1. 3D Printer
  2. Screwdriver set
  3. Soldering iron and solder
  4. Wire cutters/strippers
Step 1:
3D Print the Parts
  1. Download STL Files: Head over to Printables page to download the STL files for all required printed components. (link here)
  2. Printer Settings: Use PLA filament and adjust your printer settings for optimal layer adhesion.
  3. Printing: Print each part and lay them out for the next steps.
Step 2:
Install the IP5328P Module
  1. Placement: Locate the designated space in the printed case for the IP5328P module.
  2. Mounting: Secure the module using the 4× M3 screws. Ensure that it sits firmly in place.
Step 3:
Assemble the Battery Holder
  1. Prepare the Holder: Cut a piece of aluminum to form the battery support.
  2. Create the Contact: Wrap the aluminum strip with aluminum wire (or your preferred conductive wire) so that it provides a strong mechanical pressure. This ensures a secure, conductive connection for the battery cells.
  3. Flexibility: Note that you can experiment with different materials (such as using a different metal or wire) as long as the connection is stable. You can also spot weld the connection for better stability and reliability.
Step 4:
Soldering Connections
  1. Wiring: Solder the necessary connections between the IP5328P module, the 18650 cells, and the output wiring.
  2. Safety Check: Verify correct polarity and insulation before powering up the device to prevent short circuits.
Step 5:
Final Assembly
  1. Integrate Components: Fit the battery pack into the printed case along with the mounted module and battery holder. Mount the case with 2x M4 screws.
  2. Secure: Ensure all parts are firmly in place and that wiring is neatly tucked away.
  3. Completion: Once assembled, test the power bank to confirm it is working correctly.
