Introduction: How to Make 30W Portable Bluetooth Speaker Box With High Bass
I made a 30 watt rechargeable speaker box using TPA3110 class-D amplifier board. It's sound quality is really awesome. There are 3 control potentiometers at which we can control volume, treble and bass. You guys also can make it easily at home.
Features of this Speaker box - I added a Bluetooth module. It has many features like we directly can insert memory card and use, We can insert pen drive, AUX Cable and also can use FM Radio.
• Watch Tutorial video on YouTube -DIY : 30W Portable Speaker Box
Let's make it,
Step 1: MDF Board
Step 2: Stick It From 5-side
Use fevicol and stick it from 5 sides as shown and use clamp to bond tightly after adding some fevicol in the gap of it.
Then put it for dry. May be 4-5 Hours.
Step 3: Make Curved Corners
After dried this box, use sand paper to make it smooth and equal from all sides, fold sand paper on thick PVC pipe or on any other surfaces as I used in picture-3 and use it to make curved surface. Rub all front corners of it as much you like.
Take your time and make it smooth as much it should be.
Buy - Sand Paper
Step 4: Stick MDF for Screws
Now take 4-Pcs MDF board and stick it at all 4 corners by keeping 6MM gap for the back panel. These 4-Pcs MDFs are for Screws.
NOTE : Here I am using 4 Pcs because its only 30W. If you are using more than 30W then please use 6-Pcs of MDF Board and stick at the middle of the box.
Step 5: Fill the Gap
Still left any gap then use fevicol and small pieces of MDF bord & mix together, Now fill the gaps with this, keep it for dry.
Step 6: Drill for the Speaker
Now make drill for 3" Speakers at left and right side of this box. I used cup drill bit of 3".
If you don't have cup 3" drill bit then please watch this video and learn how I drilled only with drill bit for speaker.
Buy - Cup drill bit
Step 7: Make Gap for Bluetooth Panel
Take measurement of Bluetooth panel at the middle of this box, Make small holes with neil and drill it after that cut it using hack saw blade and make smooth by rubbing with sand paper.
Next put old dead Bluetooth module inside of this gap and make drill according to the screw size both sides.
Buy - Drill Machine
Step 8: Bass Tube
Make another 2-drill gap at the down of Bluetooth module to put bass tubes. Here I used electrical wiring PVC pipe for bass tubes.
hI used
Step 9: Cover Back Panel
Next put back cover into the box and make 4-drill gap for the screws where we added 4 small MDF Boards. Then use another bit to make 3MM big hole in drilled gap to get inside the head of screws.
Step 10: Make Smooth at Back Side
Now guys cut extra out MDF Board and make it smooth by rubbing it with sand paper.
Step 11: Drill for Switch
Drill for SPST switch at the back panel.
I like to put it at right back corner.
Step 12: Paint the Box
Next we have to paint the speaker box and its back panel.
I am used golden color spray paint. You may paint stylish.
Wait until it's not getting dried.
Step 13: Drill for Switch
Sorry, I forgot to drill for12V DC female power supply jack. So make drill also for it and then
Step 14: Drill for Speakers
Drill for speakers at the inside of this box. Be careful drill should not be cross the MDF Board.
Step 15: Screw the Speakers
Now put 15W + 15W speakers and tight it using screws.
I prefer zipsum screws because I like it more and make washer for screws. To make washer I used piece of PVC pipe.
Step 16: Bass Tube
Stick bass tube pipes using Glue stick. I made these bass tube pipes by own using electrical wiring PVC pipe.
Step 17: Tight Bluetooth Module
Now I soldered 7805 Voltage regulator IC to the input of this bluetooth panel to get continuous 5V power supply. And tighten it to the speaker box.
Step 18: Drill for Potentiometers
To add Volume, Bass and Treble control drill three holes at the top panel of this speaker box.
Step 19: Make Gap for Potentiometers
For volume, bass and treble potentiometer's nozzel are not perfect to get inside of this 6MM MDF board so please make half gap drill as shown in the pictures to get inside of it at the inside of the top panel.
Step 20: Connect Wires
Now connect the all wires of amplifier board and bass, treble board.
I used TPA3110 class-D amplifier board and transistor bass, treble board.
To understand it's wiring please watch my videos on YouTube -
Step 21: Stick Potentiometers With Glue Stick
Stick potentiometers with glue stick and also the amplifier board & Bass, treble board.
Bind the wires using tie.
Step 22: Connect Battery
Now connect the 12V Battery and connect wires of 12V charging socket and switch. I used 1N4007 PN-Junction diode in forward bias to the charging socket.
This circuit was assembled using loose wiring, which works fine for testing but is not ideal for long-term use. A custom PCB would reduce wiring errors and noise. You can order PCB from (Click here👉) NextPCB to make this project more robust and professional.
or copy link 👉 https://www.nextpcb.com/?code=KishorKumar
Step 23: Cover the Back Panel
After that stick battery inside of it and fix the back panel to it and screwed it. Even here I am using zipsum screws.
Step 24: Final
Put the knob of Volume, Bass and Treble and turn on the switch and connect to the bluetooth & play songs..
Uses it's all functions.
• Check it's Volume, Bass and Treble is working or not. If not working then fix it.
NOTE : You can use a Power Light if you want, I don't like in this speaker box that's why I didn't added.
• Please watch it's tutorial video on YouTube - DIY : 30W Portable Speaker Box
Buy Components Here -
4. 12V Battery
9. Glue stick
10. Spray paint
11. SPST Switch
13. Drill Machine
14. Cup Drill Bit
15. Fevicol
16. Tie
So this was the steps to make it guys.
Let me know your opinion about this speaker box in the comment box.
Thank You for being here
