Introduction: DIY 3D PRINTER VERSION 2 CODE NAME 3D UNIVERS
This is how i will convert the first version of my 3d printer in to the second version.
Step 1:
At the beginning the idea was to build a cnc router.
Step 2:
Here was the finishing of the cnc router build.
Step 3:
Here is how i convert my cnc router in to a 3d printer.
Because the cnc router have making a lot of noise i decided to convert hem in to a 3d printer. This was the first version of my 3d printer witch i called 3D UNIVERS VERSION 1.
Step 4:
So i bought LM10UU linear ball bearings.
Step 5:
Shaft coupler 5mm to 8mm flexible coupling.
Step 6:
Anycubic ultrabase heated bed and glass plate.
Step 7:
M5 thread t nut for 3030 aluminium profiles.
Step 8:
Usongshine stepping motor 17HS4401S .
Step 9:
Magnetic print bed tape for 3d printers.
Step 10:
This is how i mount the magnetic bed tape.
Step 11:
This is the first print on the magnetic bed tape.
Step 12:
12v 30A 360W power supply
Step 13:
This is how i mounted the power supply.
Step 14:
I have printed bracket for 3030 aluminium profiles.
Step 15:
I have printed T slot L type for M5 screw for my diy 3d printer.
Step 16:
I have printed another type of brackets for 3030 aluminium profiles.
Step 17:
This is the mounting of 3030 aluminium extrusion profiles parts with T slot L type 90 degree connector brackets and 3030 corner angle brackets.
Step 18:
I designed an shaft support for 10 mm rod and 3030 aluminium extrusion profile.
Step 19:
Here is how i mounted the LM10UU bearings in the 3d printed bearing housing.
