Introduction: DIY 3D Printed Mechanical Cat Clock
This is a mechanical cat clock that can be entirely printed. All the parts are dimensioned to fit on build plates at least 22x22cm in size. The clock measures 48x56cm in dimensions (excluding the weight) when assembled. The weight is designed like a container that has a screw lid, which can be filled with rice or sand.
(This Clock is the actual scale of my cat)
This print job requires less than 700g of filament, which means it will cost only $15-$25 to complete.
https://youtu.be/B8HdxAMvBuM
Print settings
Layer height: 0.2mm
Infill: 15-20% (pendulum weight 80% infill)
Seam: All gears should have the seam placed in a small notch (in PrusaSlicer, the seam position should be Nearest or Aligned, in Cura it should be set to the Sharpest corner).
Post-processing
No post-processing should be necessary, but check that all gears and nuts have a smooth top surface. If not, sand down any imperfections gently.
Colour scheme
These are the filaments I used and the parts I used them for
Blue star PLA+ by wool3d
Midnight Black PLA+ by wool3d
Lubrication
Applying silicone or Vaseline with a small brush is crucial for the proper functionality of moving parts.
Remember! All the files for each step are listed below the step.
Supplies-
The model consists of 99% 3D-printed parts, so you will need a 3D printer. I used my trusty Ender 3, and if the Ender 3 can handle it, then any 3D printer should be able to print this model easily.
Super glue
Thread (I used fishing line) to hold the weight
Magnets (optional)
Screw or Nail for hanging the Cat clock on the wall
Spray Paint (Optional)
*The Distance between the hanging holes is 18 cm.
Step 1: Assemble the Cat Frame
*CAT body Folder prints
"Please assemble the seven parts, including the missing piece. Each frame piece should connect easily using the eyeball connector, but be sure to avoid the elephant foot to ensure a perfect fit. These connections will hold the cat frame firmly. Add the hole connector from the backside using super glue or any other sticky substance. This will make the frame sturdy and lock it in every direction."
*Download the Files from down below for the body
*Download both files of the back connector
Step 2: Gears #1
*Gear 10 teeth - 7 units
"Please arrange the gears in their designated positions as depicted in the provided image. after that to lock the gear in place screw the end nut"
*3D model file link below every step from now to check how gears look in 3d space and for downloading.
Step 3: Gear #2
*Gear 10-10 teeth
Step 4: Gear #3
*Gear 20 teeth - 3 units
(screw Magnet end nut-2 on this - (upper gear only))
Step 5: Gears #4
*Gear 11 teeth
Step 6: Gears #5
*Gear 22 teeth - 2 unit
(screw Magnet end nut-3 on this - (gear facing toward the head))
Step 7: Gears #6
*Gear 30 teeth
Step 8: Gear #7
*Gear 30-10 teeth
(bigger gear face down)
Step 9: Gear #8
*Gear 20-10 teeth
(screw Magnet end nut-1 on this)
Step 10: Gear #9
*Gear 30-20 teeth
Step 11: Gear #10
*Gear 24-10 teeth
(Smaller gear face down)
(support needed while printing)
Step 12: Gear #11
*Pulley Gear
(gear will face down while Pully will face up)
Step 13: Gear #12
*Gear 20-8 teeth
(screw Magnet end nut-2 on this)
Step 14: Gear #13
*Gear 80-20 teeth
Step 15: Gear #14
*Gear 20-30 teeth
Step 16: Gear #15
*Gear 35-22 teeth
Step 17: Gear #16
*Gear 35-20
Step 18: Gear #17
*Gear 100 teeth
(The smaller gear inside the 100 teeth gear is just for looks, this smaller gear has no functionality)
Step 19: Gear #18
*Gear 50-10
Step 20: Gear #19
*Escapement Wheel
(Small gear face down while escapement face up)
Step 21: Pendulum #1
*Pendulum
Attach the pendulum to its desired place, and make sure to lubricate it for smoother movement.
Step 22: Pendulum #2
*Pendulum Weight
  1. Attach both pieces using 3d printed dowels (these are for only alignment, glue should be applied while joining the piece.
  2. Slide the tail of the pendulum in the rectangular slot and screw it using a gear nut).
(support may be needed while printing (depending on your printer))
(recommend to print this in 80% infill)
Step 23: Clock Dials
*Second Clock Dial , * Minute Clock Dial , *Hour Clock Dial
Print the dials (clock face), I recommend printing with 2 colours for the numbers to look good and easy to read, or like me, you can do a spray job later on.
(Soon I will release 2-3 versions of dials, like Roman numbers dial etc.)
I have attached neodymium magnets, approximately 6mm to 8mm in diameter, to the back for easy removal of the clock face. If you prefer not to use magnets, you can simply use a glue gun to attach it. If you decide to glue them directly, you can skip putting magnetic nuts on some gears as told in the instructions.
Step 24: Clock Claw
*Clock Claws
Glue the Claws of the clock on Gear (ofc, the ones with clock dial).
(Soon I will release more claw designs, and love it if someone wants to share their claw design)
(download as per your choice)
Step 25: Weight
*Weight box
After hanging the Clock on the wall.
Print this container with a lid and fill it with rice or sand. Around 500g was sufficient for me to run this clock, but this may vary depending on density and gear friction. I used a fishing line to hang the weight, but you can use any kind of thread as long as it can handle the weight. Securely tie the rope and then fasten the other end to the pulley's small hole. Next, rotate the thread on the pulley until the weight reaches the desired height. I used around 1 meter of fishing line, but this may vary depending on your wall height and other factors.
*Conclusion - Since it's a mechanical clock, the weight only provides about 10-20 minutes of runtime. I know that's very low, which is why I've already started designing an attachment that will make this clock electric without altering its appearance. Even the cables, motor, and electronics will be hidden in a way that won't be obvious, making it look like a traditional Electric clock. I'll be sharing the details of the attachment very soon.
Step 26: How to Set Up Time
It's very simple to do-
  1. Unscrew the Gear with the claw.
  2. Aligned the claw with the perfect time.
  3. Slide the gear back and screw it.
