Introduction: DIY 3D Projection Mapping With VDMX
Hello, my name is Dominic, or Doctype. I am a music producer and visual artist of sorts. Earlier this month (JAN 2nd 2014) I was booked to play a show and wanted to do more than the typical show. So I decided to try my hand at 3D Projection mapping. I stumbled onto a software titled VDMX, which offer the ability to manipulate the video composition, allowing mapping onto 3 dimensional objects. With the software in hand I set out to build something cost effective, visually stimulating, easy to transport, and a breeze to setup. Here are the results.
Download The VDMX Template Here
https://dl.dropboxusercontent.com/s/d5bjdfs4n1p7bgx/DaibatecVDMX.zip
LINK FIXED FEB13 2014
Step 1: Design and Supplies
Here is a short list of supplies I used to build this 3D Mapped Panel Rig.
Foamcore Panels- (2)30"x40" (4)20"x30"
Tape
Velcro
Plastic, stackable Crates
Cable Ties
A Projector and Computer capable of running VDMX
For my design, I wanted something lightweight, easy to transport, versatile, and of course nice and bright. The solution was foam core panels, which I bought at my local hobby shop. The large panels cost $8 dollars while the smaller panels cost $6. 6 Panels were purchased in total. 2 - 30"X40" and 4 - 20"x"30".
Tape
Velcro
Cable Ties
Step 2: Build
I arranged the panels then taped them together in a way as to allow folding, yet when unfolded remained seamless.
Use cable or outdoor ties to tie the crates together, adding stability. You may also add weight to the crates during setup.
I applied velcro strips to the back of the panels as well as to the plastic crates. Then carefully mounted the panels onto the crates.
Situate the projector and you are ready to map!
Step 3: Using VDMX to Map the Object
Now that the panels are in position, lets open our template and get to mapping.
www.doctypemusic.com/DaibatecVDMX.zip
Here is an extensive video and documentation for using my 3D Mapping Template for VDMX (Daibatec).
Here is a demonstration video of the capabilities of the template and VDMX 3D Projection Mapping!
Happy Mapping friends!
-Doctype
Contact doctypebeats@gmail.com for any questions.
-Doctype
